ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
pretty slick.... BUT... whats it cost. there are a ton of comparable choices out there (IMG:style_emoticons/default/smile.gif) Like This
is it baffled inside? any more info on its construction? whats the group buy price? BTW - nice mallory E-Coil Interested |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
interested.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
intrested
ConeDodger |
pretty slick.... BUT... whats it cost. there are a ton of comparable choices out there (IMG:style_emoticons/default/smile.gif) Like This is it baffled inside? any more info on its construction? whats the group buy price? BTW - nice mallory E-Coil Interested I agree that there are a ton of comparable choices... I have two sitting in my rear trunk. I just think this one is slick because it drains back into the engine. As it says, Chris will give details on construction and cost... |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Give us the details and I might be interested, I was going to rig up a CB old-style breather kit but this one looks better sealed etc.
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
interested
914nerd |
Who you callin' a "Member"? ![]() ![]() Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 ![]() |
also interested, depending on cost of course
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
There is only one issue with a system like this mounted in the engine bay..
In the winter when the heat is turned on (if you have heat) the vented gases from the breather that is open into the engine bay will be picked up by the cooling fan. This forces the gases through the heater boxes where they meet with hot air. The result is a funky smell that will give the driver a headache in just a few minutes of driving. Been there- done that. It's a great product just mount it in the rear trunk or vent it outside the engine bay if you have heat. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Price is $140, shipping and paypal included. Update 5/31/07: price changed to $130.
Unit includes - 2 side inlets (1/2" fittings), bottom inlet/outlet (1/2" fitting), top mounted filter (1" fitting), mounting ears, fuel cell foam inside for baffling. Minimum sale for the GB price - 20 units. Additional discount for 2 shipped in one box - $5 ($125ea) |
ConeDodger |
Price is $140, shipping and paypal included. Unit includes - 2 side inlets (1/2" fittings), bottom inlet/outlet (1/2" fitting), top mounted filter (1" fitting), mounting ears, fuel cell foam inside for baffling. Minimum sale for the GB price - 20 units. Additional discount for 2 shipped in one box - $5 ($135ea) I will take two Chris (IMG:style_emoticons/default/biggrin.gif) |
JmuRiz |
Question, what kind of fittings are used on the heads? My PO removed the head venting when he converted to carbs (IMG:style_emoticons/default/sad.gif)
ConeDodger |
Question, what kind of fittings are used on the heads? My PO removed the head venting when he converted to carbs (IMG:style_emoticons/default/sad.gif) I think they are NPT but IM McMark and ask him that. I think he has a source. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well.
ConeDodger |
URY914 |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well. Are you doing something else then Paul? Not really, but I should JB weld the nipple to the head than use a hose clamp on the hose to nipple connection. Always found it stupid to use a hose clamp on the hose when you can pull the nipple out of the head with little effort. |
Jake Raby |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well. Are you doing something else then Paul? We drill and tap our LE series heads for thread in pipe thread fittings.... The same can be done with stock heads. |
URY914 |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well. Are you doing something else then Paul? We drill and tap our LE series heads for thread in pipe thread fittings.... The same can be done with stock heads. If you're gonna do it, do it right. I'd expect nothing less from ya Jake. |
ConeDodger |
Ok... The details are on the table. Who else is in?
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Count me in. Can I get it before the weekend? (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 02:28 PM |
