installing rear window to engine lid seal, what lube works best? |
jmmotorsports |
May 17 2007, 08:26 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
I am going to replace the door window scrapers and the rear window to engine lid seal and would like to what lube is working best.
Jerry |
r_towle |
May 17 2007, 08:40 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The window rubbers will slide right in, but if you want talcum powder is the best.
The one under the rear window is pushed on horizontal from the rear. Take off the lid, cant do it any other way. The new one should have a metal strip inside. It needs no lube, push it on and I tap it with a rubber mallet to make sure its all on straight. Rich |
rhodyguy |
May 18 2007, 07:22 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
glycerin works well too. you can find little bottles of it at most any drug store. load the chanel for the squeegee and the portion that slides in. after you get the squeegees in, let them rest overnight, at a minimum, before you do any trimming. they usually stretch a bit and will return to their normal length. trim before they rest and they might windup too short. the glycerin is a good perservative for all your seals.
k |
2-OH! |
May 18 2007, 12:49 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
I'll tell you how I do it, but don't tell anyone cause' they will make fun of me...
For the seals that slide into channels or tracks, I use cooking oil...Just pour some into a small cup, Q-tip it into the channels real good and on the rubber...Then slide em' in... Works great, doesn't attack the rubber over time, readily available, cheap, washes off the car paint and you probably already got some in your kitchen...Doesn't matter about low fat, corn, vegetable or Low Trans Fat, etc...Just works really well... And if you get stuck somewhere, you can always make french fries... Window to engine lid seal just pushes on as described above... 2-OH! |
SirAndy |
May 18 2007, 01:01 PM
Resident German Group: Admin Posts: 41,661 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It needs no lube, push it on and I tap it with a rubber mallet to make sure its all on straight. (IMG:style_emoticons/default/agree.gif) just did that a few days ago. no lube needed ... (IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 28th May 2024 - 06:41 PM |
