How do you align all the cockpit seals?, Ready for re-assembly |
Allan |
May 18 2007, 06:49 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
For those of you who have done this before, How do you go about making sure that all of the seal channels are installed in the optimum position to give you the best sealing?
I've noticed that the channel pieces for the windshield, vertical targa, and horizontal targa top seals have a diagonally slotted hole for the mounting screws. This seems like a good thing because it allows some adjustment when trying to get the best seal possible, BUT, from what I can tell, the only way to really get an accurate measurement is if the seal is in the channel and you can make necessary adjustments. The biggest problem I see with this is that the seal has to be installed in the channel for this to work but, with the seal installed, you can't make the adjustments because the screws are covered. Advize please... |
Allan |
May 18 2007, 08:05 PM
Just re-installed the exterior door handles.
I've heard it can be a real PITA but it actually went fairly well. (30 minutes?) |
Maltese Falcon |
May 18 2007, 10:49 PM
Advanced Member Group: Members Posts: 4,700 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Allan, here's an interesting DIY article from a past "Panorama".
I use a mild soap/water mix when installing the outer door-window seals (in the slot) and lots of persuading (IMG:style_emoticons/default/sad.gif) Marty |
jk76.914 |
May 19 2007, 06:05 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Lookin for the same advice... don't want to risk my new front door/top seal by having to adjust it after it's installed....
http://www.914world.com/bbs2/index.php?sho...mp;#entry894522 |
PRS914-6 |
May 19 2007, 12:11 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
So reading the article it would seem that the later tops were the change and not the body? This is good timing since I am just starting to block my top for paint. Don't want to do all the work if an upgrade is in order......
Lo-Fi Version | Time is now: 9th June 2024 - 05:18 PM |
