Changing to non-staggered tire setup ..., what changes need to be made? |
Eddie914 |
May 21 2007, 10:11 PM
Unregistered |
I'm having trouble finding 245/45/16 "R" tires anymore.
I had been running: 225/50/16 on 8 inch wheels - front 245/45/16 on 9 inch wheels - rear ... with about 3-4 psi tire pressure differential. If I switch to 225/50/16 on 8 inch wheels both front and rear, what suspension setup changes can be anticipated? I would do this just to use my current collection of front tires in 225/50/16. TIA Eddie |
woobn8r |
May 27 2007, 05:46 PM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
I would think that less tire(less grip/more oversteer) in the rear would mean less rear anti roll bar, less spring and or less pressure...you'll need to find a pressure your 225s like in the rear...best done with a pyrometer... You may need to alter the front as well to balance the car...
245/45R16 R compounds seem to be available at Tire rack.... |
grantsfo |
May 27 2007, 07:19 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Hoosier R6, BFG R1, Kuhmo 710 and V700, Toyo RA1, Michelin Pilot Sport Cups are all made in 245/45/16 and 225/50/16.
Lo-Fi Version | Time is now: 1st June 2024 - 03:09 AM |
