| Dr Evil |
May 27 2007, 01:33 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I remember no too long ago someone posted a bitchen link to a mini V8 made from 2 hyabusa engines. It was a great idea, but out of the price and consideration range for probably all of us. This got me to thinking, though. The hard part is having to cast a block and a crank to fit the hyabusas together. While this engine is by far the bset choice for car applilcations due to its overwhelming power, there has to be another, easier alternative.
I was wondering how hard it would be to take 2 honda V4 1100 engines (pretty common and easy to get) and make the out put of one to the shaft of another. This would remove any need for a contiguous case/crank and yet serve the same purpose. The hondas came to mind because it is what I am familiar with in teh V4 configuration. They would be compact, easy to plumb, high rev, relatively low maitenance, and high in cool factor. Or, how about mating two large V engines together = more tq, lower reving, air cooled (or not). With the ponies that the motorcycle engines are pushing these days, adding 2 togather would give a light car like ours a nice boost and probably be lost of fun. Any thoughts? If I had it my way I would mate two BMW K1100 16V engines together in a flat opposed 8 configuration, but thats a bit out of my skills level. |
| alpha434 |
May 27 2007, 02:01 PM
My member number is no coincidence. ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Didn't we have a thread on this? Where we bashed me for an entire night for saying that it was possible?
It's been done numerous times before. with many different types of engines. |
| VaccaRabite |
May 27 2007, 03:14 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Any thoughts? Aside from the cool "Look what I did" factor, I am not sure that I would see the point of it. Depending on the person, though, the "Look what I did" factor can be one hell of a draw. It is the reason that many of us rebuild these cars. I know that 'Busa engines have been put into Minis (old body, not current) and Smart cars, to great effect. But bolting 2 engines together for a 914 would probably be more hassle then it was worth, with all the other good and "relatively" cheaper options. In the end though, all it takes is money and time. (which, as a med student, you are deficit both (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif) ) Zach |
| SirAndy |
May 27 2007, 03:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
just weld two type 4 cranks together and make a nice 3.4L out of two old 1.7s ... (IMG:style_emoticons/default/welder.gif)
nothing like a aircooled flat /8 !!! (IMG:style_emoticons/default/smilie_pokal.gif) Andy |
| McMark |
May 27 2007, 03:33 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Did the 'factory' flat 8 914s have the trunk cut?
| Dr Evil |
Hey man, dreaming in free!
Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... |
| SirAndy |
May 27 2007, 03:34 PM
Did the 'factory' flat 8 914s have the trunk cut? yes ... (IMG:http://www.914world.com/specs/prototypes/914111_002.jpg) |
| Dr Evil |
Good question of the factory 8s, I have no idea how they fit that in there and had the transaxle not poking out.
| SirAndy |
May 27 2007, 03:39 PM
Good question of the factory 8s, I have no idea how they fit that in there and had the transaxle not poking out. look at the factory drawing of 914111 in DGVWPB, page 86/87 ... it's a detailed engineering drawing of the car and how it was modified. the transaxle has been moved backwards quite a bit and the axles run at an angle. it also has a custom shift linkage going down the pass. side of the car ... (IMG:style_emoticons/default/bye1.gif) Andy |
| Dr Evil |
May 27 2007, 03:41 PM
I was just considering your welding of 2 1.7s together and it would only = about 140hp....but it would look neat (IMG:style_emoticons/default/wink.gif) At least the bike engines would put out more.
How the hell do ya get two cranks welded together? The engine would be very long (IMG:style_emoticons/default/biggrin.gif) |
| Dr Evil |
May 27 2007, 03:45 PM
"look at the factory drawing of 914111 in DGVWPB, page 86/87" Im not familiar with this notation. Where is it? |
| 914-8 |
May 27 2007, 03:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
| SirAndy |
I was just considering your welding of 2 1.7s together and it would only = about 140hp....but it would look neat (IMG:style_emoticons/default/wink.gif) well, "while you are in there", you could update the cams and such, make some nice headers and get 8 cute little carbs and you should be pushing 200 HP ... btw. here are the factory drawings ... note the shift-rod routing! (IMG:style_emoticons/default/w00t.gif) Andy (IMG:http://www.914world.com/specs/prototypes/914_8_tech_drawings_2_side_view.jpg) (IMG:http://www.914world.com/specs/prototypes/914_8_tech_drawings_1top_view.jpg) |
| SirAndy |
May 27 2007, 03:51 PM
| Dr Evil |
May 27 2007, 04:04 PM
Danke!
Ya, while Im in there (IMG:style_emoticons/default/dry.gif) Two mated TIV would be even longer. Sounds like the prefect engine for the 914 limo that I have been wanting to build. |
| woobn8r |
May 27 2007, 05:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
Hey man, dreaming in free! Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... You can get in excess 0f 230HP our of a normally aspirated rotary engine and it'll rev forever.... Add another rotor (3) and put yourself in the 350 hp range... Then you can turbo it...or add yet another rotor or both... ....if small lightweight, high HP, high revving engines is what you're after.... I've even seen the thread on putting a rotary in a 911..... |
| alpha434 |
May 27 2007, 05:15 PM
you guys are funny. You wouldn't double the horsepower and maintain the same redline just by sticking two engines together. You now have twice as much rotating mass and more strength deficiencies in the case. You don't even have roughly the same characteristics of 2x one engine. Period.
| TJB/914 |
May 27 2007, 05:41 PM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,479 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
Hi Guys,
You can put a chevy into anything if you have enough money & skills. Look at this one!!!! (IMG:style_emoticons/default/rolleyes.gif) Tom Attached thumbnail(s) |
| Dr Evil |
May 27 2007, 05:58 PM
Hey man, dreaming in free! Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... You can get in excess 0f 230HP our of a normally aspirated rotary engine and it'll rev forever.... Add another rotor (3) and put yourself in the 350 hp range... Then you can turbo it...or add yet another rotor or both... ....if small lightweight, high HP, high revving engines is what you're after.... I've even seen the thread on putting a rotary in a 911..... That is not exactly my whole point. A rotary would also cook you pretty good and be rather uninventive (been done to death). I like the motorcycle idea, not that I am going to do it before I am 50 as I will be paying back loans....(IMG:style_emoticons/default/dry.gif) |
| messix |
May 27 2007, 06:03 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
you guys are funny. You wouldn't double the horsepower and maintain the same redline just by sticking two engines together. You now have twice as much rotating mass and more strength deficiencies in the case. You don't even have roughly the same characteristics of 2x one engine. Period. geez guys!!!!!!!!! how can you just ignore him like this? such prime flaming fodder! THAT NEW ALPHY MATH! 100+100= 70 is that right alphy? |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:30 PM |
