| cobra94563 |
May 31 2007, 10:15 AM
Chris ![]() ![]() Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I'm attaching flared FG rocker panels.
I attached the top edge along the door sill and at the fenders and wondering if I should tap screw in the bottom edge as well? If anyone done this, thanks. (IMG:style_emoticons/default/confused24.gif) |
| SGB |
May 31 2007, 10:35 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I don't think you should penetrate the floor pan. What I did was drill a hole in the bottom edge of the rocker and attach (are you ready?) a binder clip so I can clip it to the ridge where the floor meets the long. I know it sounds pretty hokey, but it works. I'll try to take a picture tonight.
| So.Cal.914 |
May 31 2007, 10:47 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
If my memory is not fuching with me the stock one does secure to the bottem with screws.
| 1970 Neun vierzehn |
May 31 2007, 10:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Chris,
I had F/G rocker panels on my '70/4 from 1978 thru last year. They were not flared however. I fastened them with small sheetmetal screws where the rocker panel was secured previously with pop rivets on the door sill. I did not fasten them on the bottom, however.Those rocker panels never gave me any problems for almost 20 years. |
May 31 2007, 10:50 AM
| cobra94563 |
May 31 2007, 10:51 AM
OK.
Also, as I attached the upper edge, the bot pulled away from the body, so it kind of goes straigh down. I have to push it in to attach and I don't know what it normally should be - angled or staright down? |
| So.Cal.914 |
May 31 2007, 11:16 AM
It's angled.
Lo-Fi Version | Time is now: 8th October 2026 - 10:32 AM |
