ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
Had the windshield replaced about a year ago, as I was doing some body work around the winsheild recently the alum trim piece started to pop up and I couldn't pop it back, seeing I am doing the body repair around the windshield I pulled the rest of the trim off, know I don't care for the look of the alum trim and would like to have the black rubber look, without taking the windsheild out what can I use to get that look?
914nerd |
Who you callin' a "Member"? ![]() ![]() Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 ![]() |
736conver here on the club sells kit using that molding over in the member vendors section
Of course, that comes with urethane adhesive and other bits for remounting a windshield (which probably isn't a bad idea if you have the time, since modern adhesives hold better than the old butyl tape Other than that, ??? |
ruddyboys |
I rember seeing that post, I have to take out the windshield to install it, I dont want to chance taking the windshield off, it cost $375 last year. I was hoping for a ruber molding to glue on the windshield were the alum was.
914nerd |
The only thing I could think of is to look around at someplace that sells rubber molding and try and find something with the right dimensions and cross section and then make a replacement
Lo-Fi Version | Time is now: 10th June 2024 - 03:19 PM |
