Help ID 6 bolt 100mm rear stub axle, 911 part/year? |
Luke M |
Jun 18 2007, 07:43 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I have two rear stub axles but not sure what they fit. (IMG:style_emoticons/default/confused24.gif)
I'm looking for some info on these stub axles 6 bolt, 100mm od any idea what year/model? Stubs fit 911 rear hubs no problem. I can take afew more measurements if needed. Thanks, Luke Attached image(s) |
John |
Jun 18 2007, 11:53 AM
Part number????
914Sixer |
Jun 18 2007, 10:07 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
They look like 66-68 Lobro stub axles. They may or may not have a part number on the top where the stub is. You will have to clean with a wire brush or wheel.
Krieger |
Jun 18 2007, 10:58 PM
Advanced Member Group: Members Posts: 4,727 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I just bought a pair of these from parts heaven. $50 each. they are designed to fit ~74 to ~77 maybe 84. They are not the same as the early 911-those are 4 bolt joints but they are dimensionally identical and will fit the early hubs with the smaller wheel bearings. This is what I'm doing. I have the parts on my bench now and am certain of this. There are many posts for this try searching 911 stubs/hubs.
Luke M |
Jun 19 2007, 08:00 AM
I looked for a part # but nothing there. I dont even see where a part # may have been. The search continues.
John |
Jun 19 2007, 09:13 AM
I just bought a pair of these from parts heaven. $50 each. they are designed to fit ~74 to ~77 maybe 84. They are not the same as the early 911-those are 4 bolt joints but they are dimensionally identical and will fit the early hubs with the smaller wheel bearings. This is what I'm doing. I have the parts on my bench now and am certain of this. There are many posts for this try searching 911 stubs/hubs. I have the 74-84 style on my car right now. In 85 or so, they went with larger bolts. |
Luke M |
Jun 19 2007, 01:40 PM
I checked the cv bolt size on the stub axle and its the same as the 914 stub axle bolts. so I must have the pre 85 911 stub axles. Which means that the 944 100mm cv's will bolt up ???
John |
Jun 19 2007, 01:49 PM
Maybe.
I'm using up to 1984 911 cv joints and modified 914/6 axle shafts, and 915 coarse spline output shafts to make mine work. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:19 PM |
