| DrifterJay |
Dec 12 2003, 12:44 PM
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
ok here are two videos of my car dying...whats going on? What should I check or do? There is a popping coming out of piston # 2 and 4...it looks like fuel is spraying out when the pop happens, and when the motor shuts off a small plume of white smoke comes out of piston#1. When I speak of the fuel and smoke coming, I am talking about it coming out of the top of the velocity stacks...It idles at 450 ish right now...odd...Skline, when you fired it up, it idled at around 900ish...like it should...Anyone have any opinions? Hopefully the videos will work...if not I will post them on imagestation or something when I get back from DMV...ciao! lol (IMG:style_emoticons/default/smile.gif)
| skline |
Dec 13 2003, 01:50 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
QUOTE(DrifterJay @ Dec 12 2003, 10:44 AM) What should I check or do? There is a popping coming out of piston # 2 and 4...it looks like fuel is spraying out when the pop happens, and when the motor shuts off a small plume of white smoke comes out of piston#1. When I speak of the fuel and smoke coming, I am talking about it coming out of the top of the velocity stacks...It idles at 450 ish right now...odd...Skline, when you fired it up, it idled at around 900ish...like it should...Anyone have any opinions? Did you get a timing light like I told you? You also need to see if you can get a carb sync tool. Buy one, or borrow one, Arron said he had one and he is not that far from you. Also, did you recheck your valve adjustment? All of these are factors. Most carbs engines pop once in awhile through the carbs, but from what you said, it sure sounds like the timing is off. Check all those things and then call me. Good luck. |
| thesey914 |
Dec 13 2003, 06:24 AM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
The white smoke is the fuel falling out of atomisation. As the engine is shut off the fuel condenses because there is no airspeed and you can see it hovering around the velocity stacks. As Skline said most carbs spit and pop...he's barking up the right tree with the other advice too.
| rhodyguy |
Dec 13 2003, 07:59 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
do you get a snap or pop when you open the butterflies? what effect do the air fuel mixtures screws have on your idle? you REALLY need to get bob tomlinsons "Weber Tech Manual" available from cb performance(follow the initial setup proceedure!) and the tool on top of the book in the picture. get the book and save yourself weeks of frustration. if you haven't done so post your engine parameters, type and size of your carbs, and your current jetting combination. contrary to opinion, not all dual carb setups snap and pop.
kevin Attached image(s)
Lo-Fi Version | Time is now: 6th September 2026 - 03:25 AM |
