> Help with clutch issue
hex123
post Jun 30 2007, 12:40 PM
I had to pull the tranny because the rear oil seal desintergraded. One neat surprise upon pulling the transmission is that PO had installed a Lightened flywheel.
So I replaced the engine seal, flywheel bearing and o ring, the original clutch disk was soaked in oil so I ordered the 215mm 6 spring one from jake raby, also replaced the throw out bearing. I Re-used the pressure plate and flywheel. the surfaces did not look bad so they were not machined just a light cleaning with sand paper to get rid of some of the oil glaze. Upon re assembly I noticed the clutch fork was not positioned all the way forward ie towards the engine, it sat in the middle of travel with only about a inch of space to the rear. thoght maybe the new disk accounts for the difference so hooked up the cable and started her up.
well i have no clutch disengagement (IMG:style_emoticons/default/headbang.gif) its as if the pressure plate is too far away and the throwout bearing cant push deep enough to disengage. Its not cable adjustment cause the clutch fork is running out of space it hits the tranny casing when the clutch pedal is all the way in.
so seeing as the clutch was working fine before i pulled it what went wrong? is there something special to be done with a light flywheel and a 6 spring disk?
any clues would be appreciated.
Replies(1 - 7)
dr914@autoatlanta.com
post Jun 30 2007, 12:43 PM
QUOTE(hex123 @ Jun 30 2007, 11:40 AM) *
someone may have installed a 911s pplate that requires a thinner disc. Upon installation of the thicker vw type clutch disc there is not disengagement
hex123
post Jun 30 2007, 01:14 PM
Thanks. The interchangeability of parts on these cars appears to be both a curse and a blessing.
any easy way to identify if it is a 911 PPlate
what is a better solution keep the thicker disk and source a stock pressure plate or keep the pressure plate a get a stock disk.
rhodyguy
post Jun 30 2007, 01:17 PM
did you install the disc with the 'snout out'? on the metal center of the disc, one side sticks out an inch or so. that should be facing the trans. you also may need to tap on the pressure plate where the pins in the fw are.
k
post Jun 30 2007, 01:43 PM
QUOTE(hex123 @ Jun 30 2007, 12:14 PM) *
if you remove the plate compare it to the old. the s is lighter aluminum and thicker. The so called "six spring" disc is just an 025 bus disc which is the same size as the 914-4 disc but less expensive! That coupled with the 901/914 styled steel faced pressure plate works just fine. Knowing that the previous owner installed a lightened flywheel he may have also installed the lighter aluminum pressure plate for quicker spin up. That needs the thin disc.
You could also try adjusting the clutch cable so tight that the arm goes all of the way back and hits the transmission case. If it then disengages you may want to look at clutch stop clutch tube problems. If it still fails to disengage, you will have to take it apart and carefully measure things. If it worked before and all you did was switch the disc the disc has to be the problem! (look also at the heads of the flywheel bolts for rubbing against the disc (flywheel cut down too far) and make sure that the ballstud cup has not worn through (these are the typical problems for lack of disengagement that you might as well look at anyway.
hex123
post Jun 30 2007, 06:55 PM
just came back from pulling the tranny yup it was the ball cup in the clutch fork, thanks for all the help.
Joe Ricard
post Jul 1 2007, 08:49 AM
CUMONIWANNARACEU
Damn it that's what I was going to say.
Pivot ball.
replace the nylon and or shim the ball out.
computers4kids
post Jul 1 2007, 09:37 AM
Love these little cars!
QUOTE(Joe Ricard @ Jul 1 2007, 07:49 AM) *
Pivot ball.
(IMG:style_emoticons/default/agree.gif) A washer under the pivot arm does miracles...as noted on the tech article on the Bird board (clutch replacement)
Been there--done that
- Lo-Fi Version Time is now: 9th July 2025 - 11:56 AM
