| jonferns |
Jul 4 2007, 07:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
ok, set aside some time tomorrow to polish my 2.0 fuchs, which many people have told me need it (IMG:style_emoticons/default/biggrin.gif) (thanks all)
I used the search function, and couldnt find too much...so, what is the best way??? I dont want to remove the anodizing, so should I go with the "mothers" power ball, and metal polish, or the actual mothers wheel polish??? I want the non-anodized parts to be nice and chrome(y) (IMG:style_emoticons/default/biggrin.gif) thanks all in advance.... -JON |
| pin31 |
Jul 4 2007, 07:27 PM
Member ![]() ![]() Group: Members Posts: 398 Joined: 30-January 07 From: Newport, Rhode Island Member No.: 7,492 Region Association: North East States |
| DanT |
Jul 4 2007, 07:33 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
can't polish the wheels without removing the anodizing...
it coats and protects the alloy.... to polish you need to remove the anodizing to get to the metal to use abrasives and polishing compounds on the actual alloy... (IMG:style_emoticons/default/smile.gif) If you are talking about just the rim and paddles, then you can use sand paper, depending on the depth of any scratches. I used started with 800 grit sand paper, used some scuff pads, 1000 grit, 1200 grit, 1500 grit and then lots of metal polish with a buffer. Attached image(s)
| jonferns |
Jul 4 2007, 07:39 PM
i currently have this stuff on my shelf...
![]() could i use this with the mothers powerball, just to get it on there (easier than by hand) ??? thanks -JON |
| Gint |
Jul 4 2007, 08:23 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I used the search function, and couldnt find too much...so, what is the best way??? I know search will turn up fuchs polishing stuff... Like this: (IMG:http://www.914world.com/bbs2/uploads/post-2-1052793969.jpg) |
| DanT |
Jul 4 2007, 08:42 PM
i currently have this stuff on my shelf... ![]() could i use this with the mothers powerball, just to get it on there (easier than by hand) ??? thanks -JON yes, that was what I used with my buffer...but depending on how bad your wheels are you may not see much improvement just using polishing cream, with or with out the power ball. |
| 914rrr |
Jul 4 2007, 09:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,038 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
Any tips on removing paint from the recessed areas? What about media blasting?
| ConeDodger |
Jul 4 2007, 09:55 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
I guess my question would be how to remove the anodizing. You will polish yourself to death without progress trying to get through it...
| orthobiz |
Jul 4 2007, 10:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
| G e o r g e |
Jul 5 2007, 01:40 AM
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None
paul i believe he's talking about wheels that have been painted black (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/poke.gif)
try some brake clean it took the paint right off a set i had (IMG:style_emoticons/default/beerchug.gif) |
| orthobiz |
Jul 5 2007, 05:48 AM
paul i believe he's talking about wheels that have been painted black (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/poke.gif) try some brake clean it took the paint right off a set i had (IMG:style_emoticons/default/beerchug.gif) Or, he could fly me out there to bleed his brakes. That's ALWAYS good for lost paint in my hands!!!!! Paul |
| 914rrr |
Jul 5 2007, 08:45 AM
paul i believe he's talking about wheels that have been painted black (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/poke.gif) try some brake clean it took the paint right off a set i had (IMG:style_emoticons/default/beerchug.gif) Yup, that's what I was talking about. Thanks for the tip. BTW, how DO you remove the anodizing if you wanted to polish them? Chemical strip process similar to removing chrome? |
| 914rrr |
Jul 5 2007, 08:56 AM
I found a link that tells DIY'ers how to remove and re-anodize aluminum parts.
http://www.atmsite.org/contrib/Newman/anodize/ Looks like lye will remove it. Another site said to use caustic soda. Sounds like some pretty nasty stuff to be messing with and the need for a big ass tank to put it in. |
| jasons |
Jul 5 2007, 09:07 AM
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
| orthobiz |
Jul 5 2007, 10:25 AM
Or oven cleaner, which I think is basically lye. I would send the wheels to Al Reed. Pretty tough to beat his work for the $ Unless you are a stubborn DIY'er. I also think you can get through some of the layer with the wheel etching compounds at your FLAPS. It's for nonanodized wheels. Try it on the back of a wheel first to see how (un)happy you are... Also, search: +refinishing +fuchs on this site's engine. Brings up lots of good threads about individual experiences. Paul |
| Gint |
Jul 5 2007, 02:02 PM
So does...
+polish* +fuch* ...and if you search for these terms in titles only... You could also try +anodiz* |
| Joe Ricard |
Jul 5 2007, 02:43 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
When I did a set I just sanded through the anodize that was pretty messed up anyway.
removed all the nicks and gouges and then polished them up. about 4 hours per wheel. |
| orthobiz |
Jul 5 2007, 07:34 PM
Just in case you were to pay someone to do them, I started investigating. Prices are what I found recently from communication but obviously I cannot speak for the individual vendors!
jamagro@juno.com sales@magrowheels.com Magro is a member of this site. Really easy to talk to, great reputation. He's done many of the Fuchs 914 wheels. I believe he polishes the spokes and paints the background a color similar to the patina of the original. Al Reed's Polishing, Inc 3010 E Coronado St Ste A Anaheim, CA , 92806-2615 Phone: 714-632-3907 FAX: 714-632-8101 Al has a great reputation, very friendly on the phone also. Will do anodization for 130 per wheel. Weidman's Wheels Harvey and Sue Weidman 1675 Wyandotte Ave Oroville, CA 95966 530 - 534 - 7903 Harvey's a perfectionist and assures me the wheels will look exactly like the original. Has some type of dual anodization process, goes through twice. Says other processes involve ?media blasting? the new anodization in the background to get the different finish. And he spends lots of time on the spare because you're constantly looking at the back of it. 300 per wheel. Wheel Enhancement 5901 Blackwelder Street • Culver City, CA 90232 • (310) 836-8908 • Fax: (310) 836-8924 Formerly Robert Wood. Hard to find out that they even DO wheels on the website, seem to be much more interested in selling new wheels. But, I did speak to a gentleman on the phone on a Saturday who seemed quite knowledgeable. Yes, the reanodize and it's 240 per wheel. Damn! Makes me wish I could just go and paint a set of Mahles! Paul |
| orthobiz |
Jul 5 2007, 07:37 PM
can't polish the wheels without removing the anodizing... it coats and protects the alloy.... to polish you need to remove the anodizing to get to the metal to use abrasives and polishing compounds on the actual alloy... (IMG:style_emoticons/default/smile.gif) If you are talking about just the rim and paddles, then you can use sand paper, depending on the depth of any scratches. I used started with 800 grit sand paper, used some scuff pads, 1000 grit, 1200 grit, 1500 grit and then lots of metal polish with a buffer. Dan, those wheels look nice. Do you have a closeup pic? Did you also do the background or just the spokes? Paul |
| DanT |
Jul 5 2007, 07:57 PM
can't polish the wheels without removing the anodizing... it coats and protects the alloy.... to polish you need to remove the anodizing to get to the metal to use abrasives and polishing compounds on the actual alloy... (IMG:style_emoticons/default/smile.gif) If you are talking about just the rim and paddles, then you can use sand paper, depending on the depth of any scratches. I used started with 800 grit sand paper, used some scuff pads, 1000 grit, 1200 grit, 1500 grit and then lots of metal polish with a buffer. Dan, those wheels look nice. Do you have a closeup pic? Did you also do the background or just the spokes? Paul I only worked on the paddles and the rim...left the anodized part alone...came out pretty nice for a total time of about 4+ hours for all 4 wheels Attached image(s)
Lo-Fi Version | Time is now: 2nd April 2026 - 01:25 PM |
