So What goes WAAAAAAAAAaaaaaaaaaaa Thunk!, Screeeeeeeeh.......silence |
GWN7 |
Jul 5 2007, 11:07 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
So What goes WAAAAAAAAAaaaaaaaaaaa Thunk! Screeeeeeeeh.......silence
Give up...so do I.......... A 914 V8 being shifted from 2nd to third at about 5000rpm and this happened..... Attached image(s) |
Danny_Ocean |
Jul 5 2007, 11:14 PM
Member Group: Members Posts: 170 Joined: 27-June 07 From: Fort Lauderdale, FL Member No.: 7,846 Region Association: South East States |
No prob...that can be fixed with a few coat hangers and some bungee cords.
drive-ability |
Jul 5 2007, 11:26 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
So What goes WAAAAAAAAAaaaaaaaaaaa Thunk! Screeeeeeeeh.......silence Give up...so do I.......... A 914 V8 being shifted from 2nd to third at about 5000rpm and this happened..... That happened to me as well, you need to put the back up washers/plate in just in-case and use 911 mounts. I guess your lucky, if its a 901 you could have broken the transmission... (IMG:style_emoticons/default/chairfall.gif) |
So.Cal.914 |
Jul 5 2007, 11:54 PM
With the sound effects my first thought was "Oh my God he hit a midget".
I would listen to driveability if I were you, he's pre med. |
Dr Evil |
Jul 6 2007, 12:18 AM
Damn Bruce, you sure got some luck.
Drive-ability is pre-med? Wanna go to Penn State? I have connections (IMG:style_emoticons/default/wink.gif) |
GWN7 |
Jul 6 2007, 12:35 AM
If it wasn't my car I would post something like "next time use bolts" (IMG:style_emoticons/default/dry.gif)
(IMG:style_emoticons/default/biggrin.gif) shit happens and you get over it..... |
Brando |
Jul 6 2007, 11:10 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Hmmm... Joe Buckle knows the answer to that one! (IMG:style_emoticons/default/av-943.gif)
EdwardBlume |
Jul 7 2007, 12:11 AM
Geez, that sucks!
Its cool you can admit it, take a picture, have a moment here, and have a good attitude about it. I'd be cursing everything! |
GWN7 |
Jul 7 2007, 12:24 AM
Well I was upset when it happened, but I had a nice walk home to get the support vehicle and I'm a firm believer if you drive a old car expect the unexpected and be prepaired to fix it.
What happened was when I swapped the trans I tightened the trans bolts but didn't tighten the adaptor to the body ones...when I shifted the torque caused the trans to move and the bolts came out of the trans mounts... |
JB 914 |
Jul 7 2007, 01:24 AM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
(IMG:style_emoticons/default/dry.gif) Brando, I'm putting your Budweiser in the sun all weekend. (IMG:style_emoticons/default/poke.gif) |
JPB |
Jul 7 2007, 05:52 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Take the Yugo approach and weld it all up. (IMG:style_emoticons/default/beer.gif)
So.Cal.914 |
Jul 7 2007, 09:06 AM
If it wasn't my car I would post something like "next time use bolts" (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/av-943.gif) |
aircooledboy |
Jul 7 2007, 09:42 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
I would add some smartass comment, but I don't have time, since I need to go out to the shop and make sure a couple of bolts are good and tight. (IMG:style_emoticons/default/huh.gif)
(IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/happy11.gif) |
GWN7 |
Jul 7 2007, 10:04 AM
Thanks Chris...........at least someone got the message (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/beerchug.gif)
JB 914 |
Jul 7 2007, 02:10 PM
Bruce,
happened to me too. i only had the car a few weeks and the PO didn't put any washers on the top of the mounts. a little gas and it pulled the bolts right thru the rubber mounts. i went with the solid mounts now. Most washers only go to 10. Mine go to 11. |
Aaron Cox |
Jul 7 2007, 08:49 PM
i went with the solid mounts now. Most washers only go to 10. Mine go to 11. (IMG:style_emoticons/default/chairfall.gif) the scrapings in the pavement are still there joe (IMG:style_emoticons/default/tongue.gif) |
GWN7 |
Jul 7 2007, 09:08 PM
Hi Joe,
someone told me off list that it happened to you just after you had got the car. That was the main reason for posting the pics. I never undid the stock bolts when I swapped the trans. The only one's I did were from the adaptor brackets. I have put about 8K on the car since I got it. I checked all the bolts from front to back when it was sitting in Hood River after the fire and getting rewired and nothing was loose then. I don't remember what the bolts fited like then. I've looked thru all the pictures from back then and can't tell if they were in further. I'm still not happy with the way the trans bolts sit in the trans yokes. They look like they should fit back another 1/2" to be solidly seated. I used a pry bar on the mounts to try and get them to seat better. The car has the 911 sport mounts already. So I'm thinking of getting new adaptor pieces made so they will seat solid in the yokes. This is a early Renegade conversion kit from when they were in California (circa April 98 from the kit bill of sale) and I hope the later pieces fit better. |
sww914 |
Jul 7 2007, 10:00 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
It sounds like these V-8 conversions need about 12 ground straps on the back of the tranny to hold it up when the bolts come out.
JB 914 |
Jul 8 2007, 12:11 PM
I'm still not happy with the way the trans bolts sit in the trans yokes. They look like they should fit back another 1/2" to be solidly seated. (IMG:style_emoticons/default/agree.gif) that's why i had Thomas make me some new ones that were 3/4 inch longer. I had him make an extra set for Skline. So, if you want i can drop them back by and see if he can make another set. Below shows the new mouint next to the renegade mount. i don't know what year my renegade kit is....it came with the car. perhaps the new renegade kit adapters are different. (IMG:style_emoticons/default/confused24.gif) I also dumped the 911 mounts and went with the solid mounts see pic of the solid mounts at the bottom. Attached image(s) |
GWN7 |
Jul 8 2007, 04:00 PM
Joe, you have a PM
Lo-Fi Version | Time is now: 10th June 2024 - 08:30 AM |
