Windshield removal - removing clips first |
watsonrx13 |
Jul 6 2007, 05:32 AM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I've done quite a bit of research on this site for the correct method to removing a windshield, but I have one big question:
How do I remove the clips below the butyl tape before I begin using the guitar string to saw it out? I've tried to remove (2) windshields and both have cracked where the clips were. -- Rob |
jmmotorsports |
Jul 6 2007, 08:25 AM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
OK, I've done quite a bit of research on this site for the correct method to removing a windshield, but I have one big question: How do I remove the clips below the butyl tape before I begin using the guitar string to saw it out? I've tried to remove (2) windshields and both have cracked where the clips were. -- Rob Take a putty knife with a narrow,thin blade,slide it between the body and the clip. Give it a tap with a hammer to cut the head of the clip off the peg that holds it in the body. You will have to replace all the clips but you should do this anyway. Jerry |
Lo-Fi Version | Time is now: 10th June 2024 - 11:19 PM |
