Fuel Injection, Need Clarification |
Cjllong |
Jul 10 2007, 08:36 PM
Member Group: Members Posts: 66 Joined: 2-July 07 From: Ukiah Member No.: 7,862 |
I'm still working on my fuel injection, although I haven't had much time. I need clarification from this website, http://manuals.type4.org/ljet/. I'm checking the double relay, wich is described on the bottom of this page, http://manuals.type4.org/ljet/components/ljet10.htm. I need clarification on this portion, "Also check the voltage at terminals 43/1 and 43/2 against ground to insure that the injection valves are being supplied with full system voltage. See the ectrical Wiring Diagram for terminal identifications." I found the diagram here, http://manuals.type4.org/ljet/introduction/ljet21.htm, and I found terminal 43, but where the heck is terminal 43/1 and 43/2?
Any help is appreciated! |
ejm |
Jul 11 2007, 05:35 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
In the diagram terminal 43 is the voltage input to the resistor pack (#12) and they want you to:
QUOTE "check the voltage at terminals 43/1 and 43/2 against ground to insure that the injection valves are being supplied with full system voltage To check that the injectors are getting voltage you would check at the terminals marked 37,38,40 & 41 at the relay or check at each injector to verify the wiring and connections.Attached image(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 06:06 PM |
