Rear Spring Rate Paint Color Code |
johnhora |
Jul 12 2007, 10:30 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Does anyone have the paint color code that was used for the rear springs on the 914. They were painted black and then had a color paint mark on the spring to designate the spring rate....I have seen some marked green and some yellow...
Thanks...John |
914Sixer |
Jul 13 2007, 07:00 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
According to the factory manual, cars built after 19 May 72 had 10mm longer springs.
Group 1 220-227 kp 1 green dot Group 2 227-233 kp 2 green dots Group 3 233-240 kp 3 green dots It also seems like I remember something about the early springs having red and or white dots on them but I found nothing in the factory manual to support this. |
davep |
Jul 13 2007, 08:13 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Mark is correct. The basic thing was that the springs had a relatively wide range of stiffness. So the factory divided this range into three groups to lessen the effect that widely mismatched spring would have on handling. Thus, only pairs of springs of similar stiffness were installed on a car. If a single spring required replacement, then only a spring of that rate group should be used for that car. It makes very little difference which rate group is actually installed; that would amount to very fine tuning.
johnhora |
Jul 13 2007, 08:39 PM
Thanks Guys...
Lo-Fi Version | Time is now: 2nd June 2024 - 11:17 AM |
