Master Cylinder blew, is the 19mm the way to go |
7391420 |
Dec 15 2003, 01:07 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
My Master Cylinder blew this past week...I noticed that Pellican says to go with the larger 19mm unit, does everyone agree? is it a direct bolt on like they say?
-Any other parts I should replace at the same time...also, whats the best way to get all that break fluid off the front of the floor pan by the pedal cluster! -Thanks!! |
SirAndy |
Dec 15 2003, 01:20 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yepp, direct bold on. in fact, when i got mine (blew the old one in commute traffic (IMG:style_emoticons/default/icon8.gif) ) it was cheaper as the original Part.
get the 19mm and don't look back ... Andy |
SirAndy |
Dec 15 2003, 01:22 PM
QUOTE(7391420 @ Dec 15 2003, 11:07 AM) Any other parts I should replace at the same time...also, whats the best way to get all that break fluid off the front of the floor pan by the pedal cluster! you might want to "rebuilt" your pedal cluster. you can get a new set of bronze bushings (not very expensive). if that has never been done, your 30 year old plastic bushings will be worn out and sloppy. as for the brake fluid, soak it up with a rag and then clean up the rest with brake cleaner ... Andy |
7391420 |
Dec 15 2003, 01:26 PM
Andy,
Thanks for the info, I just noticed that Strasse has the 19mm unit for cheap$$ I usually go Pellican for most stuff, but Strasse is like $40 cheaper |
Lo-Fi Version | Time is now: 31st May 2024 - 07:17 PM |
