Got my CSP Breather, Anyone install one of these? |
thomasotten |
Jul 17 2007, 09:47 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I got my CSP breather in from the land of my fathers. Very big though. Anyone install one of these, and where did you put it? I was thinking of mounting it on the firewall.
Attached image(s) |
thomasotten |
Jul 18 2007, 11:32 AM
Bump!
Oh, come one, don't tell me everyones breather says "Bugpack" on it! |
JmuRiz |
Jul 18 2007, 01:18 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Mine does, haha.
How about on the area between the engine bay and the trunk? I have no idea how big that breather is but that'd be a place it could be more hidden and out of the way...just an idea. |
Cano |
Jul 18 2007, 01:19 PM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
No, mine actually says "EMPI"
(IMG:style_emoticons/default/biggrin.gif) It is mounted on the firewall, though |
sww914 |
Jul 18 2007, 01:31 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Mine says Kirkland Almonds, but it's transparent so I can see if it's full.
Joe Ricard |
Jul 18 2007, 02:18 PM
Mine says Kirkland Almonds, but it's transparent so I can see if it's full. is that roasted almonds? (IMG:style_emoticons/default/chairfall.gif) |
sww914 |
Jul 18 2007, 02:39 PM
Mine says Kirkland Almonds, but it's transparent so I can see if it's full. is that roasted almonds? (IMG:style_emoticons/default/chairfall.gif) You bet! |
G e o r g e |
Jul 18 2007, 02:44 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
what did that run ya? and how big is it?
por73914 |
Jul 18 2007, 03:29 PM
I don't know what the hell I am doing... Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 |
ConeDodger |
Jul 18 2007, 03:37 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I got my CSP breather in from the land of my fathers. Very big though. Anyone install one of these, and where did you put it? I was thinking of mounting it on the firewall. Thomas, If this was me, I would be torn... You have put a great deal of attention to detail into your car and in many ways it looks to be stock when in fact it isn't... I had never heard of that breather but it is beautiful for sure... On the one hand I would want it out of sight because of how stock your car appears, on the other... That thing is kind of sexy looking. Options would be the firewall down low unless it drains back oil to the crankcase the way my CFR/Spunone does. Otherwise, up under the engine lid??? |
rhodyguy |
Jul 18 2007, 04:42 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
is that for a 4 cyl engine? are you going to hook the drain lines to the heads?
k |
Rand |
Jul 18 2007, 05:04 PM
Mine says Kirkland Almonds, but it's transparent so I can see if it's full. (IMG:style_emoticons/default/laugh.gif) Classic. And I'm betting yours cost less, even with that transparency feature. |
thomasotten |
Jul 18 2007, 05:26 PM
Here is the layout of how it is to be hooked up on a Type I.
(IMG:http://www.csp-shop.de/shop/images/techtips/13816.jpg) I found out about this breather from this shoptalk thread. Basically I am wanting a a closed system, which this should do. The box is about 12" X 6", excluding nipples. Cost a little over $100 shipped from Germany. |
rhodyguy |
Jul 19 2007, 08:49 AM
no matter where you install it, it's going to require quite a bit hose. both carb draw thru and return to heads...complex.
k |
Aaron Cox |
Jul 19 2007, 09:45 AM
please dont run them down the carbs.....
heads, and filler neck are good enough. |
thomasotten |
Jul 19 2007, 10:10 AM
type11969 |
Jul 19 2007, 11:35 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Search for posts by raygreenwood and PCV on the STF type 4 forum, lots of good information there about setting up a closed system.
-Chris |
Lo-Fi Version | Time is now: 8th June 2024 - 07:27 PM |
