> Pushrod tube seals, Whats the best way to ensure no leaks?
JeffBowlsby
post Dec 15 2003, 09:53 PM
Ok so I know that I need to use the Viton seals and meticulously clean the bores of any debris/contaminants/oil. Beyond that my recollection is that there are different approaches:
1. No Lube. Lay em up dry. Is this recommended and does this work?
2. Lube 'em. What works? 30 wt? Silicone grease?
3. Some kind of adhesive...hi-temp silicone?...but dont they need to move with engine expansion?
Tell me what to do...so I dont have to do it twice... (IMG:style_emoticons/default/confused24.gif)
And Thankyahs!
Replies(1 - 4)
john rogers
post Dec 15 2003, 09:55 PM
I use a good coating of hi temp Amsoil synthetic grease. I also use it on the o-rings of our 1987 930 and it never melts or leaks.
URY914
post Dec 15 2003, 10:00 PM
The best way to insure no leaks?
Don't put oil in it. (IMG:style_emoticons/default/wink.gif)
Paul
Jake Raby
post Dec 15 2003, 10:27 PM
Engine Surgeon
Teflon thread sealant... Loctite 574 and Viton seals.
I have built hundreds of these engines and this is the only way to seal them completely that I have found.... also ensure that all Burrs and sharp edges are non existant in the case and head bores, else it will cut the o rings and leak like mad.
The art of building a leak proof engine was harder than any other TIV aspect I have ever attempted.... I've had it down since about 1991, but still have a leaker that needs some touch up on the dyno every now and then.
2-OH!
post Dec 16 2003, 08:11 AM
Jake,
Sorry to seem dumb but...
Can you give a quick detail on the Loctite and the Thread sealant...Where and how do you use which...
I have the Viton seals..
2-OH!
- Lo-Fi Version Time is now: 31st July 2025 - 11:27 AM
