Help in getting 74 914 2.0 running again |
WilRod |
Jul 20 2007, 12:09 PM
Newbie Group: Members Posts: 8 Joined: 17-July 07 From: Brooklyn, NY Member No.: 7,915 Region Association: North East States |
I need help in getting my recent acquisition running again. I was drivig it and it conked out after a loud backfire-like sound. Now it tries to start but I can't keep RPM going. Suspect F.I. problem. I need some guidance and/or the name of a good mechanic who is familiar with these cars in the metropolitan New York Area.
orthobiz |
Jul 20 2007, 12:46 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
John Paterek in ?Chatham, NJ will know of a good mechanic. Google Paterek Brothers.
Paul |
orthobiz |
Jul 20 2007, 12:52 PM
OK, this may sound silly but something like this happened to me except no loud backfire. I get my car for the first time and after one day of driving, the RPM's cut out to zero and the engine will not run. It starts up no problem but will not continue running. Turns out I had a defective ignition switch (even though it was brand new!).
Do this: turn the ignition key to the first position. You should hear the fuel pump go for about 2 seconds and stop. And you should have electrical power: the brake light should be on, generator light, the radio should work, etc. If not, it's a bad ignition switch. They crack and fail frequently enough that Pelican has a good picture article on it. They rate the difficulty 3 on a scale of 1-10. Also in the "Restore and Modify" book on the 914. The cheap fix is to hold the key manually past that first position a little bit while driving. Makes it hard to shift, though.......... I repaired mine within an hour and was up and running! Paul |
Lo-Fi Version | Time is now: 8th June 2024 - 07:43 AM |
