> Cam gear bolts, How much torque
trojanhorsepower
post Dec 16 2003, 09:46 AM
Any one ... any one ... Buler?
Mine are the allen head kind.
Thanks
-Pete
Replies(1 - 6)
trojanhorsepower
post Dec 16 2003, 06:17 PM
I found it 20 ft lbs if any one wanted to know.
-Pete
redshift
post Dec 16 2003, 06:20 PM
Bless the Hell out of you!
How far along is the re-do?
M
trojanhorsepower
post Dec 16 2003, 06:30 PM
I have finished tearing everything apart and I posted the #'s for Jake to match up the bearings. Throwing caution to the wind I went ahead and assembled the crank (cleaned everything and matched the bearings back up and got the caps all on there right). If Jake says they are the wrong bearings than I will just take it all apart again.
I called CB and got the torque for the cam gear so I will bolt that on shortly and set the cam timing. If I get the OK form Jake I will put the case back together tonight and start getting all the through bolts set up. May not torque them down till tomorrow, but we shall see. If I can ever get rolling I could have the motor back to long block in a few hours.
-Pete
P.S. Redshift, I bet you wish you hadn’t asked now.
Jake Raby
post Dec 16 2003, 08:02 PM
Engine Surgeon
I need more numbers. call me.
torque the bolts to 18 lb/ft and use red loctite
HarveyH
post Dec 17 2003, 07:03 AM
Be VERY SURE to use the Loctite. The PO's builder didn't. (IMG:style_emoticons/default/mad.gif) Bolts walked out, ate the oil pump, strange noises, metal shavings in the engine, BAD! (IMG:style_emoticons/default/headbang.gif) BAD! (IMG:style_emoticons/default/headbang.gif) BAD! Evil thoughts upsetting my karma (IMG:style_emoticons/default/ar15.gif)
Harvey
trojanhorsepower
post Dec 17 2003, 03:39 PM
HarvyH
Yep, I did. My PO went the other way though, he used JB Weld!!!
I had to use some heat to get them out so I could put the gear on right.
-Pete
- Lo-Fi Version Time is now: 22nd September 2025 - 10:33 PM
