Angle Grinder, Which should a 914 owner own? |
maf914 |
Dec 16 2003, 11:58 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I just returned a Mikata 4" angle grinder to Home Depot. It was the first of these I had bought and it seemed like a decent buy at $49. What I didn't know was that most grinders have a 5/8" shank while the model I bought had a metric M10-1.25 shank. Of course no one, including HD, carries tool accessories for that shank size and I would have had to order things from Mikata. I checked with two industrial suppliers without luck. So I figured I would bail out and start over.
So my question is: What is the preferred grinder make and size for general auto and home work? 4" or 4.5"? Are all 5/8" shank grinders the same when it comes to accessories, or are some easier to equip? I want to use the usual accessories like brushes, grinding and cutting disks, etc. Any suggestions will be appreciated. Mike |
RON S. |
Dec 16 2003, 12:54 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Mike,
As I've done mods to (IMG:style_emoticons/default/welder.gif) and continue to do mods to my 6r over the last 5 yrs.Heres a list of the tools that have become my best friends. A 4"Dewalt angle grinder.My Dremel.A pneumatic straight die grinder,for use w/carbide cutters.A pnuematic angle grinder. I've used my Dewalt for 5yrs steady.Ya can't tell it's yellow anymore but it still gets the job done. For a grinding,grind your welds with a flapper wheel type grinding pad.They are about 7-8 bucks a piece at welding supply places.They maybe a steep price,but they produce less heat than a hard disk,and polish out a weld nicely. Ron |
fiid |
Dec 16 2003, 01:46 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I have a $36 or so Ryobi grinder which I got from Home Despot. It's met all o0f my needs.
Fiid. |
stock93 |
Dec 16 2003, 01:56 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I have a black and decker professional 4.5 in angle grinder. All the standard attachments work with it. We have had it for around 5 years. Its still going stong and I use it pretty roughly. I also have a 4 in craftsman angle grinder as well. I dont like it as much. It doesnt seem to have as much cutting/grinding power. I also dont like that the on off switch is on the left side of it. My black and decker has the switch on the bottom of it which it much more comfortable when working with it for long periods of time.
John |
cha914 |
Dec 16 2003, 02:43 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
I have the el chepo Harbor Freight 4" grinder that they always have for sale (about 15bucks I think) ... didn't expect it to last, but its been two years now and I still can't kill the thing...all the normal attachments work with it.
I actually have several of their air tools (nibbler, pneumatic angle grinder, air hammer, cut off wheel, etc) and I have not had a problem with one...course they only get mild use, but they do the job for about 1/10th the price of the good IR or Blue Point stuff... Tony |
mightyohm |
Dec 16 2003, 02:58 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I have a Harbor Freight 4.5" angle grinder, and know 3 other guys who have them too, and they have put a lot more use on theirs. They are dirt cheap and they work well.
Compatable with std attachments too, which you can also buy dirt cheap at HF. |
JWest |
Dec 16 2003, 03:07 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I had the Harbor Freight and a Black & Decker Professional. Both 4 1/2". I used to have a Makita 4" with the metric spindle - a pain because nothing would fit it.
The Harbor Freight was lent to a friend and stolen along with a few other tools (guess which friend no longer gets to use my stuff?). When I had it, there was little difference between it and the B&D, except it was much less expensive to buy. The HF grinder I got even came with replacement motor brushes! |
sj914 |
Dec 16 2003, 05:05 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Harbor freight, Sears, Home Depot are all good stores to buy from. DON'T ever buy any of those .99cent grinders off ebay. i bought 2 of them and they didn't even last a day. Shit bushings plastic gears forget it.
btw I use the 15.00 Harbor Freight 4" grinder and it works very well. |
Dave Bell |
Dec 16 2003, 05:17 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
The harbor freight units are so cheap that you can buy more than one.... keep a wire cup brush on one, a grinding disk on one, a straight wire wheel on the other... sure saves time from having to change attachments on and off.
I do the same thing with the Harbor Freight air die grinders... I must have 4 of those units with various attachments just sitting on them waiting to be used.... |
URY914 |
Dec 16 2003, 05:22 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Dave,
You're right-I do the same thing. Changing the attachment is a PITA when you only need it for a minute. I bought another grinder and put a sanding disc on it. Saves time. Paul |
Dave Bell |
Dec 16 2003, 05:26 PM
By the way...
Ask Mikey Z. what happened to him when he was using a wire brush on an angle grinder and wearing floppy sweat pants.... |
URY914 |
Dec 16 2003, 05:31 PM
I have one of those B&D with the switch that is a paddle on the bottom and I took the guard off. Be careful when setting it down as the weight of the grinder will turn it on.
not too safe... Paul |
rezron |
Dec 16 2003, 06:05 PM
Member Group: Members Posts: 327 Joined: 25-December 02 From: Mason City, Iowa Member No.: 10 |
I've got a makita like you mentioned- did'nt hve any problems finding what I needed for attachments. Seems to
work fine! rezron |
BIGKAT_83 |
Dec 16 2003, 06:11 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
QUOTE(Dave Bell @ Dec 16 2003, 03:17 PM) The harbor freight units are so cheap that you can buy more than one.... keep a wire cup brush on one, a grinding disk on one, a straight wire wheel on the other... sure saves time from having to change attachments on and off. I do the same thing with the Harbor Freight air die grinders... I must have 4 of those units with various attachments just sitting on them waiting to be used.... (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
TimT |
Dec 16 2003, 09:02 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I have 3 angle grinders, a B&D,Makita,and a cheapo Harbor freight unit. Like mentioned before I have different things mounted on each one
Dec 16 2003, 09:13 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
Hmm, I'm gonna goto harbor freight tomorow to pick some stuff up. arg, spend more money.
My friend had a harbor freight heat gun, 2nd time he used it, it started to smell funny, then 2 seconds later, it burst into flames. (IMG:style_emoticons/default/confused24.gif) |
sj914 |
Dec 16 2003, 09:46 PM
QUOTE(L8Apex @ Dec 16 2003, 07:13 PM) My friend had a harbor freight heat gun, 2nd time he used it, it started to smell funny, then 2 seconds later, it burst into flames. (IMG:style_emoticons/default/confused24.gif) Well it's not exactly a bbq grill. |
Gint |
Dec 16 2003, 10:39 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I have a Dewalt that just keeps goin, and goin, and goin... but the switch likes to come unlocked during use. Especially with a big heavy 4" wire cup brush. I bought a $15 HF unit aso so I wouldn't have to change tools so often. Both have 5/8" arbors.
Jake Raby |
Dec 16 2003, 11:03 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The old Makita's are much better.... They had the universal shanks too... the new ones don't.
Had mine for 12 years. It has decked many, many 1.7 rocker arms..(even a set on maf914s engine:-).. hard to kill! |
Dec 16 2003, 11:15 PM
QUOTE Well it's not exactly a bbq grill. Don't think I haven't tried that (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 11:21 PM |
