whitey |
Member ![]() ![]() Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 ![]() |
I'm trying to get the correct distributor installation in regards to the vacuum advance cannister. Does someone have a picture of their distributor that they can send me.
Thanks, Dave |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Where is Ball joint when you need him.
There is a picture in the factory manual and in the haynes. and the rebuild Type IV engine book (red cover) |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
when properly "indexed", the vacuum canister is located toward the top seam of the engine cases. if indexed wrong (thanks scott, but that's another story...) you might not be able to set the timing of the engine because the canister hits the case before the correct timing can be reached.
whitey |
Thanks for the help....I'm now good to go!
Dave |
Lo-Fi Version | Time is now: 16th June 2024 - 06:31 PM |
