whitey
Jul 24 2007, 04:20 PM
I'm trying to get the correct distributor installation in regards to the vacuum advance cannister. Does someone have a picture of their distributor that they can send me.
Thanks, Dave
Joe Ricard
Jul 24 2007, 04:22 PM
Where is Ball joint when you need him.
There is a picture in the factory manual and in the haynes. and the rebuild Type IV engine book (red cover)
type47
Jul 24 2007, 06:22 PM
when properly "indexed", the vacuum canister is located toward the top seam of the engine cases. if indexed wrong (thanks scott, but that's another story...) you might not be able to set the timing of the engine because the canister hits the case before the correct timing can be reached.
whitey
Jul 24 2007, 07:49 PM
Thanks for the help....I'm now good to go!
Dave
