Master cylinder replacement/service, Remove fuel tank??? |
whitey |
Jul 24 2007, 09:43 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I'm getting ready to service my brake master cylinder...Do you have to remove the fuel tank to reinstall the two lines from the fluid tank?
Thanks, Dave |
skline |
Jul 24 2007, 09:59 PM
Only if you pull them out to replace them. You will be draining all your brake fluid however so you will need to bleed all 4 corners.
dflesburg |
Jul 24 2007, 10:05 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Get under there, you may need some long skinny plyers to help you, that was how i did mine last night...
you can get everything in with fuel tank in place... |
TravisNeff |
Jul 24 2007, 10:22 PM
You might need to remove your pedal cluster for easier access, 2 nuts on the inside of the cabin, remove the hard lines at the MC and out it comes. You do not need to remove the tank.
geniusanthony |
Jul 25 2007, 12:16 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
When I removed mine I took a few days until I reassembled everything and had to re-figure out which line was which. It does take a little while though and can be messy but enjoy.
Hopefully others will chime in with some more help |
mzapisek |
Jul 25 2007, 12:36 PM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
The tank can stay in. It's a messy job and I agree with Travis, it's easier if you remove the pedal cluster first. If you haven't gone to bronze bushings yet now is the time while the pedal cluster is out (also a fun job). Remember not to touch your paint during the process as brake fluid does bad things...ask me how I know?
Joe Ricard |
Jul 25 2007, 01:11 PM
Tough part is getting those Effin grommets that are around the supply lines. back in the top of the M/C. You can get more wiggle room by taking the mounting bracket off the resevoir.
Lo-Fi Version | Time is now: 1st June 2024 - 02:31 PM |
