Quick transmission questions |
KaptKaos |
Jul 30 2007, 10:32 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I resealed my transmission this weekend with the help of young Aaron.
We took everything out and got it all back together. It didn't look too bad either. (IMG:style_emoticons/default/biggrin.gif) Question is: Which way does the differential go back into the case? Big side down? We're 99% sure, but I want to double check. I don't want 5 speeds in reverse. TIA. |
bondo |
Jul 30 2007, 12:19 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I resealed my transmission this weekend with the help of young Aaron. We took everything out and got it all back together. It didn't look too bad either. (IMG:style_emoticons/default/biggrin.gif) Question is: Which way does the differential go back into the case? Big side down? We're 99% sure, but I want to double check. I don't want 5 speeds in reverse. TIA. The ring gear goes on the driver's side. So I guess that would be "down". You can also verify by noting that the engine turns clockwise when looking at it from the front. |
KaptKaos |
Jul 30 2007, 02:54 PM
The ring gear goes on the driver's side. So I guess that would be "down". You can also verify by noting that the engine turns clockwise when looking at it from the front. The side of the transmission that you can take off is on the passenger side, as that is where the clutch pulley connects. Is that correct? If so, then the ring gear would be on the driver's side, as that was "down" when we dropped the diff through the hole in the side of the case. Sound right to you? Thanks! |
bondo |
Jul 30 2007, 07:28 PM
Sounds right! (or is that left?) (IMG:style_emoticons/default/biggrin.gif)
Make sure you put it in before the gear stack! (for obvious reasons) |
KaptKaos |
Jul 30 2007, 08:45 PM
Aaron Cox |
Jul 30 2007, 08:50 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Brando |
Jul 31 2007, 01:46 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Joe! My solid trans mounts are yours. I got 'em off. Shoot me a PM!
KaptKaos |
Jul 31 2007, 06:41 PM
Joe! My solid trans mounts are yours. I got 'em off. Shoot me a PM! Did they fall off? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) |
Brando |
Aug 5 2007, 06:09 PM
Ha ha ha ha ha NO.
They were still attached... The trans is what fell off LOL. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:17 AM |
