What Battery Is Best For A 914?, Please share your thoughts... |
kfieler |
Aug 6 2007, 01:56 PM
kfieler Group: Members Posts: 71 Joined: 26-July 07 From: Southern California (Mojave Desert) Member No.: 7,949 |
Okay... after sitting 10 years, this 1973 914 1.7 is cleaned-up, "prepped" and ready to be started! BUT FIRST I NEED A BATTERY! 1. I am considering an Optima "gel" battery, but don't know which one is going to work best for a car with "stock" battery tray and stock battery cables. Red top or Yellow top? Top post or side post? If you have an Optima, which one do you use? 2. What is the best way to mount an Optima battery to a stock battery tray? 3. I have never started the car and don't know if the engine is "junk" or not. Therefore, in your opinion, should I jump into an expensive (Optima) battery or first buy a cheap "Pep Boys Special" and replace the battery with a "gel cel" later if I decide to keep the project going? 4. Am I overlooking any other options (other than a cheap conventional or Optima battery)? I really appreciate any feedback you experts out there can provide! Thanks in advance for your input! - Keith |
orthobiz |
Aug 6 2007, 04:38 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Rand |
Aug 6 2007, 05:32 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Optima red top 34R. (Yellow top is deep cycle - best for applications that run down between charges, unlike a car that has an alternator keeping it topped off.)
I like the Odyssey PC680 because it has enough cranking power and it is a lot smaller/lighter. If you have a lot of accessories drawing on the battery though, you may need the larger Optima. |
jimtab |
Aug 6 2007, 11:28 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Optima red top 34R. (Yellow top is deep cycle - best for applications that run down between charges, unlike a car that has an alternator keeping it topped off.) I like the Odyssey PC680 because it has enough cranking power and it is a lot smaller/lighter. If you have a lot of accessories drawing on the battery though, you may need the larger Optima. (IMG:style_emoticons/default/agree.gif) Love mine. |
Joe Ricard |
Aug 7 2007, 08:42 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Oddessy PC680
12 pounds can be laid on it's side/upside down/ right side up. don't matter. There is one a step bigger also if your car is hard starting. |
kfieler |
Aug 7 2007, 10:58 AM
Oddessy PC680 12 pounds can be laid on it's side/upside down/ right side up. don't matter. There is one a step bigger also if your car is hard starting. That is great information! I was not familiar with Odyssey Batteries until this thread. I've seen Optima installations, but never an Odyssey in a 914. Does anyone have a photo they could share (showing what the Odyssey looks like installed in a 914)? Thanks! - Keith |
Joe Ricard |
Aug 7 2007, 11:31 AM
Mine is not in the stock location. But it will lay down just perfect in the battery tray. You can use a metal strap or Nylon strap to hold it down.
I did not get the posts. Just put some soldered loop cable ends on the cables and secured them with the cap screws included with the battery. |
Rand |
Aug 7 2007, 12:47 PM
Does anyone have a photo they could share (showing what the Odyssey looks like installed in a 914)? Stock location on it's side, ala Retrotech... (IMG:http://www.914world.com/bbs2/uploads/post-1302-1151773209.jpg) Mark (mskala)... (IMG:http://www.914world.com/bbs2/uploads/post-2-1116092337.jpg) Rear trunk ala JP... (IMG:http://www.914world.com/bbs2/uploads/post-45-1153265378.jpg) More pics can be found by searching for "odyssey." They have also been mounted in the cabin behind the passenger seat and in the front trunk, among other places. Personally I wouldn't run the heavy cable all the way to the front trunk for such a light battery. |
anderssj |
Aug 7 2007, 03:49 PM
Dog is my copilot... Group: Members Posts: 1,659 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Just put another Optima 34R in my car--to replace the one I bought in 1992 (that one got moved to moved it to the 914 sitting at the shop).
I use a quick disconnect on the negative terminal, so there's no drain on the battery when the car is parked. COuld be part of the reason it lasted so long? Best, |
mskala |
Aug 8 2007, 11:43 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Wow, I don't even have to post any more (IMG:style_emoticons/default/laugh.gif) my pic is already there
Rand |
Aug 8 2007, 11:56 AM
Wow, I don't even have to post any more (IMG:style_emoticons/default/laugh.gif) my pic is already there (IMG:style_emoticons/default/laugh.gif) From a previous thread. Nicely done. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:47 AM |
