Rennshift |
Rennshift |
kojo2001 |
Aug 9 2007, 10:30 PM
Member Group: Members Posts: 88 Joined: 22-June 07 From: california Member No.: 7,832 |
I am sure this has been discussed before but what is your opinon or experience with this upgrade?????
Thanks |
BigDBass |
Aug 9 2007, 10:45 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Hiya,
The short answer: Just about everyone with a Rennshift seems to love it. Just about everyone that doesn't have one, wants to get one! The long answer: Run a search in the Garage (where this message should be) for Rennshift and you will find several threads with feedback on it. Also, I think there is a post in the Member Vendors area that also has info about the Rennshift and more customer feedback about it. |
736conver |
Aug 10 2007, 12:13 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
jasons |
Aug 10 2007, 07:32 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I don't think you will find one negative review for it. I will say, if you haven't taken care of everything else (bushings etc.) in a sloppy shifting car, you will be wasting your money.
914nerd |
Aug 10 2007, 09:41 AM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
It's well worth it
And this is coming from someone who is at least as cheap as the rest of you |
Chris Pincetich |
Aug 10 2007, 10:28 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I realized last winter that my 914 was evolving into a weekend AX fun car, and bought a Rennshift before James raised the price $35. The 2-3 plane is soooo solid, and since most AX races are 2nd and 3rd gear for 90% of the course, it has helped immensely. Super confident 3->2 downshifts and 4->3 downshifts and never grind reverse on the 1->2 upshift. (IMG:style_emoticons/default/driving.gif)
If you're primary cruisin, it might be overkill, but if you like pushing things a bit, it will almost eliminate embarassing (and costly) missed shifts. The bushing comment is right on, gotta have the entire system solid for the Rennshift to work its magic. (IMG:style_emoticons/default/beerchug.gif) |
scotty |
Aug 10 2007, 11:18 AM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
It goes to 11 -- I love mine.
smokey |
Aug 10 2007, 11:29 AM
Senior Member Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None |
3.2 / rennshift (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smoke.gif) . not to many 07/08 cars can stay with me.. turbo 911 can get me . This upgrade is the bomb. Veteater
kojo2001 |
Aug 10 2007, 12:57 PM
Thanks
woobn8r |
Aug 10 2007, 04:38 PM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
3.2 / rennshift (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smoke.gif) . not to many 07/08 cars can stay with me.. turbo 911 can get me . This upgrade is the bomb. Veteater Can you run the rennshift/3.2/915/sideshift set up? Or is that a cable application? S. |
HAM Inc |
Aug 10 2007, 04:40 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
I love mine. A real quality piece.
JWest |
Aug 12 2007, 03:34 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
woobn8r |
Aug 13 2007, 09:26 AM
Thanks James...
I'll have to research this more when I'm nearer to that phaze of my project...nice to know there are options. Sorry for the hi-jack. S. Can you run the rennshift/3.2/915/sideshift set up? Or is that a cable application? S. There are a few (non-cable) linkage options for converting the 915 to mid-engine use. They all use a 911 style shifter, and the 911 RennShift works great in this application. |
Lo-Fi Version | Time is now: 29th May 2024 - 05:12 AM |
