Refinishing dash face, Question about area around heater controls |
Lavanaut |
Aug 21 2007, 12:07 AM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Search turned up lots of good info answering some other questions I had, but not this one. I pulled/replaced my heater controls while doing my dash recovering project. I just started rewiring the controls, before refinishing the dash, when I realized that this might be a mistake. Becuase I didn't have a factory dash to start with though, I don't have a good point of reference.
I'm rambling. Here's my question: is it only the chrome trim piece surrounding the heater controls that covers the dash face vinyl, or do the heater controls themselves overlap the vinyl as well? Here's a "before" pic, kind of blurry, sorry. You can see the wood just sits up against the edges of the controls (not underneath them at all). Can someone who's done this project please confirm that this is how the vinyl should be cut as well? I want to make sure I'm not screwing myself by installing the heater controls before I attach the new dash face. Thanks |
PRS914-6 |
Aug 21 2007, 12:24 AM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Vinyl goes on first and then the entire assembly slides in. So the answer to your question is the heater controls themselves overlap the vinyl.
Lavanaut |
Aug 21 2007, 12:55 AM
Hmmm. I just went out and looked at the pieces. It looks to me like, if the control unit itself sits on top of the vinyl, the chrom trim piece would stick out too far, leaving a gap between itself and the vinyl.
This is a quick drawing, as if you're viewing a cross section of the dash face. With the controls sitting on the vinyl, and the chrome trim piece sitting on the controls, won't there be a gap? (IMG:style_emoticons/default/confused24.gif) Thanks for the reply by the way! |
Jasfsmith |
Aug 21 2007, 08:05 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
The trim pieces I have seen typical are vinyl covering adhered to a thin metal backing, which in turn are secured to the dash structure with a thin double stick foam tape. The vinyl does sit behind the chrome bezel of the heater controls. |
Lavanaut |
Aug 21 2007, 11:14 AM
The trim pieces I have seen typical are vinyl covering adhered to a thin metal backing, which in turn are secured to the dash structure with a thin double stick foam tape. The vinyl does sit behind the chrome bezel of the heater controls. I left the metal backing plates out of my drawing for simplicity's sake...but yes, I do have those. I think you're confirming my suspicion though, that the face of the heater controls sits flush with the vinyl facing (not on top or overlapping it) and that it's only the chrome trim piece that overlaps the vinyl, yes? I feel like I'm not getting my point across very well. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/burro.gif) |
markb |
Aug 21 2007, 11:27 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
The trim pieces I have seen typical are vinyl covering adhered to a thin metal backing, which in turn are secured to the dash structure with a thin double stick foam tape. The vinyl does sit behind the chrome bezel of the heater controls. I left the metal backing plates out of my drawing for simplicity's sake...but yes, I do have those. I think you're confirming my suspicion though, that the face of the heater controls sits flush with the vinyl facing (not on top or overlapping it) and that it's only the chrome trim piece that overlaps the vinyl, yes? I feel like I'm not getting my point across very well. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/burro.gif) the face of the heater controls sits flush with the vinyl facing (not on top or overlapping it) and that it's only the chrome trim piece that overlaps the vinyl, yes? Yes |
Lavanaut |
Aug 21 2007, 11:55 AM
Lo-Fi Version | Time is now: 5th June 2024 - 04:19 AM |
