> painting Fuch wheels
RonnieJ
post Aug 22 2007, 12:17 PM
RonnieJ
What type of black paint is used on the 914 Fuch wheels and can you rattle can them or is it best to take them to a painter?
Replies(1 - 9)
dr914@autoatlanta.com
post Aug 22 2007, 12:20 PM
QUOTE(RonnieJ @ Aug 22 2007, 11:17 AM) *
No paint! they are completely annodized. the 914-6 fuchs uses matt black (flat) in between the spokes
SLITS
post Aug 22 2007, 12:23 PM
"This Utah shit is HARSH!"
The American Eagle? fakies were painted matt black!
RonnieJ
post Aug 22 2007, 12:44 PM
RonnieJ
Thanks
Cap'n Krusty
post Aug 22 2007, 02:34 PM
Cap'n Krusty
Paint was applied at the dealer level. They used rattle cans where I worked. Lot boys did 'em. The Cap'n
SLITS
post Aug 22 2007, 02:42 PM
QUOTE(Cap'n Krusty @ Aug 22 2007, 01:34 PM) *
Somehow I can't see you as a go-fer .... even at a younger age.
I did Jaguars / Austin Healys (IMG:style_emoticons/default/biggrin.gif)
Scott S
post Aug 22 2007, 03:38 PM
Small Member
I know they dipped the original early 5 bolt fuchs to add the black background. When you respray the black, is there a better way then using masking tape to get a straight line?
I know they sell wheel masking kits for the MG crowd....
pete-stevers
post Aug 22 2007, 04:30 PM
saved from fire!
some alternatives to drab boring ......black
pete-stevers
post Aug 22 2007, 04:31 PM
saved from fire!
and surprised this one isn't salmon..... (IMG:style_emoticons/default/bootyshake.gif)
Jasfsmith
post Aug 23 2007, 08:30 AM
QUOTE(Scott Schroeder @ Aug 22 2007, 05:38 PM) *
You'll chuckle at this method.
A friend of mine had a set of so-so 5 bolt Fuchs with the anodizing pretty much gone. He degrreased the wheels completely, set up a flat bottom tub, placed the wheel front side up, and poured in satin black paint until it reached the correct level partially coating the pedals. Removed them carefully, placed them on a raised grille and let the paint drain and dry. Exceptional finish. No masking to deal with. Only down side I could see was the waste of paint.
- Lo-Fi Version Time is now: 31st July 2025 - 10:57 AM
