Heater controls - wiring question, Error in Haynes? |
Lavanaut |
Aug 22 2007, 04:14 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
The three-prong connector on the right/rear side of the heater controls (controls fan speed) has three colored wires running to it: white/green, white/yellow and plain white. Both my Haynes and Clymer manuals state that the order from left to right should be green, yellow, white. When I pulled mine out though, it was wired yellow, green, white, as shown in the pic below. I'm wondering if then manuals are mistaken (they share the exact same pic, actually) or if one of the POs wired it back up incorrectly.
Anyone know? Thanks |
Lavanaut |
Aug 24 2007, 11:02 AM
904svo |
Aug 24 2007, 11:37 AM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
All the matters is if the blower speeds work right, low, medium and high with the switch. |
Phoenix-MN |
Aug 24 2007, 11:40 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I think Low speed = I
Med speed = II High Speed = III |
Lavanaut |
Aug 24 2007, 11:46 AM
Phoenix-MN |
Aug 24 2007, 12:34 PM
I think Low speed = I Med speed = II High Speed = III That's in agreement with what my manuals say, too. I think I'll wire it back up that way. BTW, where'd you get the nice colored diagram? Thanks Pelican (The Bird Board) http://www.pelicanparts.com/914/914_electrical_diagrams.htm Paul |
Lavanaut |
Aug 24 2007, 12:37 PM
Ah, cool. Thanks Paul!
Lavanaut |
Sep 29 2007, 06:00 PM
All the matters is if the blower speeds work right, low, medium and high with the switch. Wow thanks. I think it's worth documenting on this site when errors in the few documents that exist for our cars are found. Maybe save some other newb confusion in the future. Anyway, I finally had a chance to test this wired both ways. Wired as Haynes suggests does not work correctly ~ only two speeds function. I wired it back up the way it was when i pulled it out and everything works as it should. Could be just my car I guess... Left--->Right: yellow, green, white Lava |
mdwman |
Oct 21 2007, 06:21 PM
Member Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 |
I have been into my blower switch recently to get it working. Discovered that the copper contact arms on the lever had been bent upward and were not making contact with the different wire connections for the fan speeds. I bent them down and the fan worked great on each speed. Unfortunately, the arms were so weak after the bending that the longer one broke off. At least I know my blower motor is good. Any suggestions on replacing that contact arm?
Lo-Fi Version | Time is now: 6th June 2024 - 10:20 AM |
