914 V8 Question, LT1 |
boxstr |
Dec 20 2003, 11:04 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Thinking of a V8 conversion still and I cam across a 1997 LT1 350 Ram air 305 hp Aluminum heads. It is a rebuilder. Owner says it had a noise in the lower end. Not a rod knock?? Heads are off and valves are good, not bent. $650.
TIA CCLINV8SWAPMODE |
seanery |
Dec 20 2003, 11:37 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
is this a truck motor or a corvette, or camaro/firebird?
boxstr |
Dec 20 2003, 11:59 PM
I will have to ask?? What are the differences?Which one would be the one to use??
CCLINLT1 |
Brad Roberts |
Dec 21 2003, 01:26 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
They never used the LT1 ram air in a truck. 305hp sounds correct for the Camaro and Trans Am. The vette should have had 350hp for that year.
The injection setup doesnt fit in the engine compartment.. and the heads are deisgned for reverse flow water pump (you would have to be VERY creative to make this setup work in a 914. B |
iiibdsiil |
Dec 21 2003, 03:10 AM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
The engine won't work because the waterpump will interfere with the firewall.
- Brett Smith |
John2kx |
Dec 21 2003, 06:07 AM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Check this post about fit of LS1/LT1 in a 914.
http://www.pors-chev.com/pipermail/pors-ch...ber/001835.html John |
John2kx |
Dec 21 2003, 06:27 AM
Not the answer to your question but when putting my v8 conversion together, I found pictures to be very helpful. This link has many 914 v8 conversion projects in various stages of completion.
http://community.webshots.com/user/adbuch John |
boxstr |
Dec 21 2003, 09:26 AM
Thanks I think the question has been answered. Anything can be done if you want to fuck with it long enough.
John, thanks I have been to both sites and they are great to use as a reference for question like the one I posted. CCLINV8HEAVEN |
rhodyguy |
Dec 21 2003, 09:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what car do you intend to do this to? low ball the guy from bremerton and use his pre-sorted stuff for the swap. i bet the cost will me nearly the same. i'm going to email you with a little insight as to that red v-8.
kevin |
John2kx |
Dec 21 2003, 10:13 AM
Craig,
Hope you share your v8 experience with this board. Most of us conversion guys fall into the lurk mode for obvious reasons. I know several here who can provide a wealth of information. They sure made my vision become a reality. John |
boxstr |
Dec 21 2003, 10:47 AM
John Thanks. I have enough 914s scattered that I won't fall into lurk mode. I have a 3.2 six that is sitting and could fit into the 914, but I started looking at what is left to do and it makes more sense dollar wise to buy a 914-8 allready done or sell the 3.2 and convert to the V8.
I am leaning towards the sage advise of Rhodyguy and buying one completed and swapping componnents from that car to the JLO car. The completed car has some body and suspension issues. I will keep you posted as to which way I turn. CCLINCHEVPORSCHMODE |
rhodyguy |
Dec 21 2003, 10:54 AM
well craig, you buy it, i'll deliver it for you and take the train home (IMG:style_emoticons/default/laugh.gif) . a one day temp licence is all it takes. i'll pay for the gas. the yellow car. well that will be subtle.
kevin |
Brad Roberts |
Dec 21 2003, 04:35 PM
John reminded me of why I dont like email based posting systems.
Craig.. you will love a V8 car.. but you wont be happy with a 901 for very long (which is where you would save some money on the 3.2 conversion. I like all 914's. Doesnt matter what is powering them. B |
boxstr |
Dec 21 2003, 10:22 PM
I thiink this is the V8 car that I am going to love. Reference to ebay for display only.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...4&category=7251 CCLINKEWLV8LUV |
Brad Roberts |
Dec 21 2003, 10:26 PM
OK.. now your scaring me.
B |
boxstr |
Dec 21 2003, 10:35 PM
sj914 |
Dec 22 2003, 12:56 AM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Looks like something you'd take to the moon. (IMG:style_emoticons/default/blink.gif)
redshift |
Dec 22 2003, 01:05 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
QUOTE(boxstr @ Dec 22 2003, 12:22 AM) I thiink this is the V8 car that I am going to love. OHMAHGAWD! You just commited battery! I think you broke my nose. M |
GWN7 |
Dec 22 2003, 01:29 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Where do you put the golf clubs?
boxstr |
Dec 22 2003, 09:07 PM
Okay folks it is coming to CAMP 914, I bought the Bremerton 914-8. 327 with 283 crank so we have a 302.Kennedy Engineering clutch and adapter kit.
Motor has a Milidon oil pan, pump and windage tray. Forged crank with blueprinted rods and ARP rod bolts,TRW forged pistons, a Comp cams 280 grind hydraulic cam and valve train, roller tip rockers. Late 80s IROC 305 heads, ported and rebuilt. Weiand Excellerator intake manifold with Holleyprojection fuel injection system. Also a complete MSD ignition including distributor,6AL boxwith rev limiter and coil. Tilton gear reduction starter Suspension has 23 mm torsion bars front,180 rear springs,larger front sway bar and Koni shocks. Stock rotors with BMW front calipers rears are 914 fronts, 911 master cylinder, electric brake lock for the E-brake. Riv wheels with 195/60 Michelins,&" wide steel wheels with Yokohama R compound tires. Autopower rollbar and 5 point harness. Body looks like it may have some issues but that will be determined when it gets here. Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:12 PM |
