914 with 911 Front end- Which Strut inserts? |
Jeff Hail |
Aug 27 2007, 01:05 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Have a question that I have not seen posted yet....
914 with a 1988 Carerra front end (Boge struts, bigger brakes and control arms with underbody sway bar. Popular upgrade for a 5 lug. Question: What inserts would be the correct pick for the front? 911 or 914? I am going with Koni adjutables and all the manufacturers Bilstein, Koni, Boge have different part numbers for the inserts for the 911 and 914 because of different valving. Anything else I should be aware of? Any problem using the new replacement 914 inserts in the Carerra/ Boge strut tubes? Are the tube dimensions the same. All I can see visually that is different is the crown nut securing the insert. Should I just order the 914 strut inserts for Boge tubes and go? |
blitZ |
Aug 27 2007, 11:38 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Richard Casto |
Aug 27 2007, 03:29 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Jeff,
I have been trying to document much of what you are asking on the Wiki page that Les mentions. The Wiki article references some good threads on this forum as well. Here is a thread I started that might have some answers to your questions... http://www.914world.com/bbs2/index.php?showtopic=70929 To answer your question, I "think" you can just use the Koni inserts for Boge struts that are valved for the 914 in the 911 Boge struts. Probably best thing to do is when ordering them to mention that you are using these in 911 Boge struts. For example I called and talked to Jason at Paragon and he should know what combos work. |
Eric_Shea |
Aug 27 2007, 05:05 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Hi Jeff:
(IMG:style_emoticons/default/welcome.png) I don't believe there are "any" inserts for that strut that are "officially" for the 914. You could get Koni and Bilsteins revalved for the application (if you deemed it worthwhile). As stated in that link, there's not too much difference between the 911 and the 914 version of the Koni. Just high speed rebound and from what I understand, it's slight. I don't believe a 914 or early 911 Boge will fit that strut. I could be wrong though... |
Jeff Hail |
Aug 27 2007, 05:38 PM
Hi Jeff: (IMG:style_emoticons/default/welcome.png) I don't believe there are "any" inserts for that strut that are "officially" for the 914. You could get Koni and Bilsteins revalved for the application (if you deemed it worthwhile). As stated in that link, there's not too much difference between the 911 and the 914 version of the Koni. Just high speed rebound and from what I understand, it's slight. I don't believe a 914 or early 911 Boge will fit that strut. I could be wrong though... Richard, Eric Thanks, I am going call Koni and Bilstein. They should at least be able to tell me if the inserts are dimensionally the same. I know the crown nuts on the strut tubes are different on the outside but I do not know about the inside. If I can get a clear answer from them I will post it. Thanks again, |
Jeff Hail |
Aug 27 2007, 08:53 PM
From Dave at TRE Motorsports.
Use the correct year inserts for the year/ model tubes. 911 inserts in 911 tubes! Any valving differences is minimal -if noticeable. That was easy...... |
Lo-Fi Version | Time is now: 7th June 2024 - 05:52 PM |
