Boxster Rims |
Boxster Rims |
pjhaun |
Dec 21 2003, 03:04 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Here is a picture of the chromed Boxxter rims on my 914 (front)
Attached image(s) |
pjhaun |
Dec 21 2003, 03:08 PM
Here is another picture on the chromed Boxster rims I put on my 914 (rear)
Attached image(s) |
Andyrew |
If only they where 17 in.. Still looks nice!
Works well with the body. (IMG:style_emoticons/default/driving.gif) Andrew |
Jeroen |
Dec 23 2003, 07:18 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Very nice!
Can you post any specs...? Wheel sizes, ET/offsets, spacers used? cheers, Jeroen |
scottb |
Dec 23 2003, 08:01 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
pj, could you have the woman in your avatar move a little to her right?
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) oh, and nice wheels too......! |
boxsterfan |
Dec 23 2003, 10:31 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Those look great! Still gives me the feel of the "era". 17" rims would be too huge. I always thing the 914's with 17" rims look a little awkward even with mondo flares.
Malmz |
Dec 24 2003, 12:07 AM
CSOBOSC founding member Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
Phillip,
Definitely interested in hearing what spacers you used (since nobody could give me an answer to my hypothetical question a month ago!) Let us know. sm |
pjhaun |
Dec 24 2003, 12:41 AM
They are stock 1997-98 Porsche Boxster rims chromed. The front is 6x16 with an offset of 5 1/8 inches. I used a 1 1/2 inch spacer. The tire I used is 205/55-16. The rear is 7x16 with an offset of 5 5/16 inches. I used a 1 inch spacer. The tire I used is 245/50-16.
smrz914 |
Dec 24 2003, 01:47 AM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
17 inch 993 wheels so you can decide if they are to big.
(IMG:http://www.pelicanparts.com/MotorCity/smrz918/P9080009_small.jpg) |
sj914 |
Dec 24 2003, 02:38 AM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Paul, the picture's too small.
I thought the 17's were too big to. But seeing your car in person with those 17" changed my mind. |
Malmz |
Dec 24 2003, 10:37 AM
QUOTE(pjhaun @ Dec 23 2003, 10:41 PM) They are stock 1997-98 Porsche Boxster rims chromed. The front is 6x16 with an offset of 5 1/8 inches. I used a 1 1/2 inch spacer. The tire I used is 205/55-16. The rear is 7x16 with an offset of 5 5/16 inches. I used a 1 inch spacer. The tire I used is 245/50-16. Any idea of how much inside clearance you have in the front at full lock? Wonder if I could run a rear wheel on front with a 1" spacer all the way around. sm |
smrz914 |
Dec 24 2003, 03:42 PM
i ended up posting the thumbnail, let's try again.
(IMG:http://http://www.pelicanparts.com/MotorCity/smrz918/P9080009.jpg) |
pnewman |
Jan 19 2006, 07:54 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
I see alot of 911 rims on ebay for sale. Occasionally cheap. Seems as though they came w/ 17" front x 7" and rear x 9" some auctionaires state a 55mm offset ??? hmmmmmmmmmmmm
has anyone tried getting 4 each of the 7" ones and putting them on a 914? would you have to have fender flares? would you have to use spacers? just looking down the road at converting to 5 lug from 4 and would only do it if I could put on pretty wheels. aaaaaaaaaaaaaaaaaaaaaah pete |
mskala |
Jan 20 2006, 11:06 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Yes, several people in several threads did 7"x16" boxster without mods. The 40mm offset is
nearly perfect. I now have a set which will hold my 205/45/16 Kumho V700's, but not ready yet. |
Mueller |
Jan 20 2006, 12:48 PM
for a just about perfect setup, a 7" rim with a 205 would need a 35mm offset, so with a 55mm offset 7" rim, you'd want to run a 20mm spacer on the rear..... for the fronts, you can actually get away with a larger spacer such as 25mm or even wider since the track on the front is 1" per side narrower on the front the rear........ |
Root_Werks |
Jan 20 2006, 02:29 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
914 looks great! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 01:11 PM |
