cables, engine heat melting insulation |
ztbell |
Sep 1 2007, 03:14 PM
Newbie Group: Members Posts: 44 Joined: 8-August 06 From: Jacksonville, Illinois Member No.: 6,619 Region Association: None |
(IMG:style_emoticons/default/gint.gif) '75 2.0, speedo, clutch cable is melting, any ideas for insulation?
thanks for your advice... : |
SirAndy |
Sep 1 2007, 03:23 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/gint.gif) '75 2.0, speedo, clutch cable is melting, any ideas for insulation? thanks for your advice... are they routed correctly? (IMG:style_emoticons/default/idea.gif) Andy (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Cap'n Krusty |
Sep 1 2007, 03:43 PM
Wrap 'em in some kind of heat resistant sleeve. Been a problem since the cars were new. The Cap'n
PRS914-6 |
Sep 1 2007, 04:01 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
All my cables, fuel lines and oil lines are are installed with heat protection made by Goodridge.
SirAndy |
Sep 1 2007, 04:05 PM
i had my headers ceramic coated inside/out ...
no heatshielding on the cables or oillines. so far, so good ... (IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
pfierb |
Sep 1 2007, 06:22 PM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
ConeDodger |
Sep 1 2007, 06:49 PM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/gint.gif) '75 2.0, speedo, clutch cable is melting, any ideas for insulation? thanks for your advice... In addition to the advice of others on insulation products, consider your timing. If your timing is off you can burn fuel in the exhaust greatly increasing the temperature in the area under the engine. |
Allan |
Sep 1 2007, 06:54 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
iamchappy |
Sep 1 2007, 07:34 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
It's called fire sleeve. I use the orange Aeroquip stuff I think it's a little easier to source than the Goodridge hose.
ottox914 |
Sep 2 2007, 08:41 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Go to almost any auto parts store. They will have, or can get products to wrap lines to prevent heat-melting. I'm using on my clutch/speedo cables a section of heat wrap for a starter. Its long enough to go from about the engine mount bar to the clutch cable bracket where the pulley wheel is. It was to wide, so I wrapped it around the cables several times. The auto parts store also has some stainless steel tye wraps, which I purchased and used to secure the double wrapped heat barrier blanket thingy. I think I was out maybe 30-40 bucks for all of it, and have had no problems. Car is at a friends house for some turbo work, he's out of town, so no pics, but I'll gry to get a few next wk to add.
ztbell |
Sep 2 2007, 02:24 PM
have pic
Lo-Fi Version | Time is now: 29th May 2024 - 04:43 AM |
