use 911 muffler straps in a 914-6 |
siverson |
Sep 16 2007, 01:42 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Hi,
I've had three mufflers crack on my 914-6 at the joint where the two intake pipes attach to the muffler. I'm using the 914-6 muffler bracket which helps support the headers (they are fine), but these two joints have to support the entire weight of the muffler. In the pre 73 911s, the muffler weight is supported by straps (see diagram below). Can this bracket and straps be retrofitted to a 914? I'm using a 915/916 transmission. Has anyone done this? Am I the only one with a very short muffler life span? -Steve Attached image(s) |
PRS914-6 |
Sep 16 2007, 01:53 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
WAY too much weight to hang off the flanges with no support further out. You have to clamp it around the middle like the 911's. I made a bracket to come off the back of the tranny and clamped it like OEM. I use a M&K which is much lighter but the concept is the same....The 911\914-6 muffler is very heavy and when you hit a bump it really creates excessive loads when unsupported.
Here is a pic |
sixnotfour |
Sep 16 2007, 06:13 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Porsche did it on the GT's
http://www.pbase.com/9146gt/rally_muffler_of_a_gt Attached image(s) |
smontanaro |
Sep 16 2007, 07:56 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Following the pbase.com link led me to M&K Exhaust which led me to RarlyL8 Motorsports who sells M&K's 911/914-6 stainless muffler for $630. 'tain't cheap, but it only weighs 14 lbs. Might be another alternative.
Skip |
siverson |
Sep 18 2007, 12:10 PM
Thanks! Looks like I need some straps!
Lo-Fi Version | Time is now: 2nd June 2024 - 06:36 AM |
