Fuel pump question. |
JOE M |
Sep 21 2007, 11:30 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
When I turn my key aux. the fuel pump makes a loud ticking noise. I can also hear it when the car is running. Is it a bad pump or could it be a faulty ground. The ground is tied back to the bracket the pump is mounted to ( rusty bracket). Or is this normal for this type of solid state type of pump. 1972 914 with carbs.
Thanks |
Cano |
Sep 21 2007, 11:49 AM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
When I was still running a carb, my facet fuel pump made a similiar noise, but always worked fine. I think it is just the nature of the beast.
rhodyguy |
Sep 21 2007, 11:55 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
does it look similar to this one? they're noisy by nature. if the mount backet is fastened directly to the chassis, metal to metal, you can lesson the racket by isolating the mounting point with a piece of rubber. keep the ground clean.
k Attached image(s) |
JOE M |
Sep 21 2007, 12:42 PM
does it look similar to this one? they're noisy by nature. if the mount backet is fastened directly to the chassis, metal to metal, you can lesson the racket by isolating the mounting point with a piece of rubber. keep the ground clean. k Looks almost identical. it is on rubber isolaters but is still loud. sounds like it might be o.k no pun. |
purple |
Sep 21 2007, 01:36 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
i had one and it jammed.
replaced it with a cb rotary and never looked back. now all i have is a low hum it would have helped if the rust from the tank didnt get into the pump, the p.o. put the fuel filter AFTER the pump, with no strainer in the tank |
Lo-Fi Version | Time is now: 10th June 2024 - 12:06 PM |
