Anyone know which direction Boxster radiator flows?, top to bottom or vice versa? |
neo914-6 |
Sep 27 2007, 03:39 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Just modified the Y pipes for the parallel plumbing but am not sure which direction the flow should be...
byndbad914 |
Sep 27 2007, 03:46 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Hey Felix - don't know the exact answer for sure about a Boxster, but I know this much - it doesn't matter which direction water flows through a radiator per se (the core is non-directional), so I would just make sure water flows in the top and is pulled from the bottom (that way gravity creates a pressure head on the water pump). You never want to try to suck from the top (somehow I see a joke coming with that statement (IMG:style_emoticons/default/biggrin.gif) )
fiid |
Sep 27 2007, 04:30 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Are you sure they are run in parallel and not in series?
neo914-6 |
Sep 27 2007, 05:33 PM
Hey Felix - don't know the exact answer for sure about a Boxster, but I know this much - it doesn't matter which direction water flows through a radiator per se (the core is non-directional), so I would just make sure water flows in the top and is pulled from the bottom (that way gravity creates a pressure head on the water pump). You never want to try to suck from the top (somehow I see a joke coming with that statement (IMG:style_emoticons/default/biggrin.gif) ) I agree it makes sense. I won't touch that last part (IMG:style_emoticons/default/laugh.gif) |
neo914-6 |
Sep 27 2007, 05:35 PM
fiid |
Sep 27 2007, 06:44 PM
Next week should be fine. At lunch time, I'm in the office on Wednesday and Friday, at other times of the day I'm around Tue, Wed and Friday.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:18 AM |
