original vinyl for sail panel, does it look like the left or right or neither |
freezing14 |
Sep 28 2007, 08:16 PM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
and if it is neither, what does it look like , ok i got 2 vinyl kits, not sure what is original and what garbage
sixerdon |
Sep 29 2007, 08:41 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
The one on the right looks like the print for the sails on the roll bar. But neither are close for the interior seats or door panels. I'm not familiar with current replacement material in the market, but the interior material should imitate stressed leather. Look at some of the interior photos in this forum.
Don |
freezing14 |
Sep 29 2007, 09:41 AM
stupid me ,, forgot to say that it is the sail panel vinyl, so i can safely assume that i have to install the right one
Pat Garvey |
Sep 29 2007, 06:37 PM
stupid me ,, forgot to say that it is the sail panel vinyl, so i can safely assume that i have to install the right one Yves, The one on the right IS correct for the sail panels. Be forewarned, though - it may shrink some after the install, and it mat take a couple of years to shrink. So, I would cut about a sixteenth of an inch (you do the metrics) larger than you need. I had one side shrink about a quarter inch, while the other side did nada - musr be an install/glue effect thing. Nevertheless, the right pic is what I call the "pinhead grain" & it's right for the sail panels. Good Luck. Pat |
freezing14 |
Sep 29 2007, 06:57 PM
cool thanks, i'll keep in mind the shrinking factor, it will look so different once that is on
I keep finding that it take so much time to reassemble I have to spend so much time cleaning bits and bits and I am always looking for that dawm special scew and once i have found it , I got to plate it , more time,, Thanks Pat Yves |
Lo-Fi Version | Time is now: 9th June 2024 - 07:07 PM |
