> Whats going on ?, Directional indicator lights
BarberDave
post Sep 29 2007, 07:36 PM
Barberdave
I decide to rebuilt all the gauges in my dash, at that time i also replace all lights
with LED's. Really like them except for both directoinal indicator lights,
they are on all the time. They still blink correctly,they are just on all the time.
Even with the small drain that supose to have on the battery, it eventually goes
dead. Mech. says " because there LED's that is the why it has to be" that just
doesen't seem right to me . Is there a RIGHT way on Wrong way to in stall LED's.
Or should I just go back to the stock blubs in that location???????
Inquiring minds what to know!
Dave (IMG:style_emoticons/default/slap.gif)
Replies(1 - 5)
BarberDave
post Sep 30 2007, 06:11 AM
Barberdave
Someone has to have a Ans.
BUMP (IMG:style_emoticons/default/icon_bump.gif)
jk76.914
post Sep 30 2007, 08:11 AM
I may be able to help figure this out. First of all, what do you mean that they blink correctly, but they're on all the time? Also, did you just replace the dash indicators with LEDs, or the front and rear outside directional bulbs as well?
This is a tricky circuit. It was designed to give you a cockpit indication of when you have a directional bulb failure. I backdated my '76 to an earlier style tach with both left and right indicator, and I had to figure it out. '76 only had one indicator that flashed for either left or right. Here's the original posting-
http://www.914world.com/bbs2/index.php?sho...;hl=directional
Jim
BarberDave
post Sep 30 2007, 11:28 AM
Barberdave
Jim: I just replaced the bulbs inside the car.
I ment when i pull the derectional lever down for a left turn the directonal
arrow blinks correctly, as it does when i push it up for a right turn.
All other times both turn arrows are on, light switch in off position.
I looked at your other post , I have a real problem with the electric systems
don't understand shit. So I think I will replace the LED's on the directional arrows
with the OE bulbs. Both types of bulbs should work ,mixed togeather in the same
gauge. Right????
Thanks for the effort
arvcube
post Oct 10 2007, 12:28 AM
QUOTE(BarberDave @ Sep 30 2007, 10:28 AM) *
could it have anything to do with your hazard lights circuit? just a thought...
Spoke
post Oct 10 2007, 07:31 AM
Jerry
Not sure I understand how they can be on all the time then blink. Do you mean they are dim then blink brightly? Or they are dim all the time then blink full on and full off?
Replacing the bulbs with LEDs shouldn't cause the battery to drain. Whether a bulb or LED, both would drain the battery, the bulb being a heavier load should drain the battery faster than the LED. When the car is off and the LED's are still on, are they on brightly or dimly? Also what voltage do you measure across the LED's with the car off?
Just out of curiosity, do the LED's have built in resistors? I assume so since the voltage of an LED is around 2V. Also what is the rated current draw of the LED's at 12V?
For my 74, I backdated to a 72 tach with L and R turn signals. I used normal bulbs and wired them directly across the front turn signals. The front (and rear) turn signal wires are routed directly to the emergency switch right by the dash and are easily accessible with the dash out.
Maybe the 914 turn signal circuit was designed to let the driver know if a bulb burned out. This would be a good thing for an auto manufacturer. I, myself, am not a car manufacturer and can take any liberty that I deem works. So my rewire of the indicator lights works perfectly for me.
Spoke
- Lo-Fi Version Time is now: 13th July 2025 - 07:34 PM
