Carb guys! Help! what size is the nut, on the end o fthe throttle shaft. |
Aaron Cox |
Dec 26 2003, 01:08 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i seemed to have lost mine. what size is the nut on the outside of the carb that connects the linkage to the carb on the throttleshatft?
please respond ASAP. |
ArtechnikA |
Dec 26 2003, 01:52 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(acox914 @ Dec 26 2003, 11:08 AM) i seemed to have lost mine. what size is the nut on the outside of the carb that connects the linkage to the carb on the throttleshatft? please respond ASAP. 'the' nut on 'the' throttle shaft ? you might start by clueing us in on WHAT KIND of carb this is. Solex? Zenith? Mikuni? Stromberg-Carlsen? Weber - and which of the dozen flavors of those ? double-throat for a 4? IDA ? IDF ? triple-throat IDTP13C for a /6 ? |
Drums66 |
Dec 26 2003, 02:03 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
we are waiting Aaron.......in the mean time go back to FI (IMG:style_emoticons/default/laugh.gif)
Aaron Cox |
Dec 26 2003, 07:40 PM
sorry guys....found the right nut. it was a weber 44.
i was driving around and all of a sudden my car lost half of its power. one side of the linkage wasnt hooked up because the nut on the throttle shaft let loose. sorry for the wait. ive been tinkering with the carbs. thanks anyway (IMG:style_emoticons/default/wavey.gif) |
rhodyguy |
Dec 26 2003, 07:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
lucky you found it. lock em down. the car drove pretty crappy for the last 1/4 mile didn't it?
kevin |
Aaron Cox |
Dec 26 2003, 07:44 PM
no...drove fine. the lock tab had worked flat and the nut spun. but the linkage connector to the carb was still on the square part of the shaft. then it fell of and i only had linlage to one carb.
Lo-Fi Version | Time is now: 1st June 2024 - 01:52 AM |
