pressure senssor |
pressure senssor |
41ghost |
Sep 30 2007, 01:42 PM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
who can i get to rebuild a pressure senssor or get instructions to rebuild myself, or just get a working one from somewhere. found that the one one myfriends car is not working and most likely is the problem with the stutter,s .
41ghost |
Oct 1 2007, 05:39 AM
know body out there know about these?
type47 |
Oct 1 2007, 06:54 AM
is it Bleyseng (sic?) who rebuilds and calibrates the MPS? search the name and that should provide contact info.
Dave_Darling |
Oct 1 2007, 10:11 AM
You rebuild them by taking them apart, then finding the NLA parts that have failed, then putting them back together. Sadly, the typical failure is that the diaphragm inside the MPS ruptures, and there doesn't seem to be a decent replacement available anywhere.
--DD |
SLITS |
Oct 1 2007, 01:19 PM
Search for Geoff Bleyseng(?) on this board .... he was doing them.
Otherwise, it is Fuel Injection Corp, Livermore, CA (bought Brett Instruments) - or Python Injection, Stanton, CA. Maybe others, but I don't know. Damp Dave is correct, but the "O" ring that seals the halves can also take a crap. Go to your local Automotive Recycling Facility (Junkyard) and get one off of a Mercedes Benz, VW, BMW, Volvo, and a few others. If it holds vacuum .... the diaphrams are still good. Use the good diaphrams in your bad unit. I can get them rebuilt if I supply extra cores with good diaphrams, but the cost will wind up being about $225 - $250 (Core +Core + Rebuild). The "rebuilt" ones that use the stamped steel diaphrams don't work real well as the steel was not as flexible as the beryllium/copper originally used. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:36 PM |
