Late model steel wheels, 7" for track tires |
DanT |
Sep 30 2007, 06:02 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
just finished the repaint on my latest aquisition
(IMG:style_emoticons/default/biggrin.gif) gloss black centers with gloss grey rims. (IMG:style_emoticons/default/shades.gif) they currently have 205x50 used but usable V710s on them. (IMG:style_emoticons/default/smile.gif) anyone have or know where I can get 1 or all four center caps for these (IMG:style_emoticons/default/confused24.gif) thanks Attached image(s) |
DanT |
Sep 30 2007, 06:03 PM
I need a center cap for this one
Attached image(s) |
johannes |
Oct 1 2007, 12:03 PM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I think Autoatlanta have them ... But I remeber they are black.
TravisNeff |
Oct 1 2007, 12:21 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Where did you score those wheels Dan? Did you buy them widened or did you have that done?
DanT |
Oct 1 2007, 12:29 PM
Where did you score those wheels Dan? Did you buy them widened or did you have that done? got them from a good friend that did not want to use them any longer, already 7" when he got them. (IMG:style_emoticons/default/driving.gif) lots of these were made in the 70s and 80s here in Norcal. Many AXers and TTers had them made to run under basically stock fenders. Some others used them for cantilever slicks under flares. (IMG:style_emoticons/default/biggrin.gif) I have a good friend that has had/built many 914 4s and almost every one on them had a set of these installed. (IMG:style_emoticons/default/smile.gif) I run 3/4" spacers in the front and 1/2" in the rear. With that spacing I have over 3/4" clearance on the inside, spring on the rear. And at least a finger width of space on the out side fender lip. This is with the V710s installed, which are a very wide 205 tire with very vertical sidewalls. I believe I could get 225s under the rear with no problems, with the use of a 1/4" spacer instead of the 1/2". Yes my fender lips are rolled and the fenders are slightly pulled. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:26 AM |
