| rascobo |
Oct 5 2007, 03:00 PM
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
Just installed new rear rotor and pad, but now the outer venting screw and lock-nut won't tighten and fluid is leaking from them. Have had this problem before, but can't remember how I resolved it.
rascobo |
| angerosa |
Oct 5 2007, 03:18 PM
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Just installed new rear rotor and pad, but now the outer venting screw and lock-nut won't tighten and fluid is leaking from them. Have had this problem before, but can't remember how I resolved it. rascobo I just rebuilt my rear caliper. There's a o-ring that keeps your break fluid from leaking out of the piston chamber into the e-brake mechanism area. venting screw???? hmmm - do you mean the bolt that is the cap for the adjustment screw? Do you mean bleeder valve maybe? Do you mean the adjustment screw won't tighten? If so take the caliper apart and rebuild. Hardest part was having the prper tool to get the retainer C clip out. If you put in new seals and o-rings and grease everything up - it will probably work fine. |
| rascobo |
Oct 5 2007, 04:05 PM
Just installed new rear rotor and pad, but now the outer venting screw and lock-nut won't tighten and fluid is leaking from them. Have had this problem before, but can't remember how I resolved it. rascobo I just rebuilt my rear caliper. There's a o-ring that keeps your break fluid from leaking out of the piston chamber into the e-brake mechanism area. venting screw???? hmmm - do you mean the bolt that is the cap for the adjustment screw? Do you mean bleeder valve maybe? Do you mean the adjustment screw won't tighten? If so take the caliper apart and rebuild. Hardest part was having the prper tool to get the retainer C clip out. If you put in new seals and o-rings and grease everything up - it will probably work fine. I'm talking about the venting clearance adjusting screw and locking nut. rascobo |
| davep |
Oct 5 2007, 04:19 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,362 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Sounds like a rebuild by Eric Shea is in order. They can be tricky to do correctly. I do them also, but he is on your side of the border.
| rascobo |
Oct 5 2007, 05:20 PM
| rascobo |
Oct 5 2007, 07:56 PM
[quote name='rascobo' date='Oct 5 2007, 02:00 PM' post='953817']
Just installed new rear rotor and pad, but now the outer venting screw and lock-nut won't tighten and fluid is leaking from them. Have had this problem before, but can't remember how I resolved it. rascobo UH-OH! Just dismantled caliper in preparation for rebuild and found cause of problem. The adjusting screw has lost its threads where the locknut would normally tighten. As right now it's My only car, if anyone in Portland,Or. has a usable passenger side rear caliper or an adjusting screw their willing to sell please contact me at r.scotbolan@gmail.com or 503-329-2665. Thanks. rascobo/Scott |
| davep |
Oct 5 2007, 09:07 PM
Call Eric Shea for parts.
Lo-Fi Version | Time is now: 15th April 2026 - 11:57 AM |
