Carbs without choke |
Thack |
Oct 10 2007, 10:03 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
How do you guys get along with the dual carb setup that offers no choke. Is there a way to add more fuel at start up or does it just run lean at start up? What do you do for the winter months? I have dual Solex H40 DEIS carbs.
Allan |
Oct 10 2007, 10:07 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I run weber 40's on my six and don't have any problem getting the car started.
ahdoman |
Oct 10 2007, 10:30 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I've got Dell 40's. Before starting the car I'll pump my accelerator a couple of times, fire it and I will usually have to hold the gas in a little trying not to exceed 1500 rpm on cold startup.
Zundfolge |
Oct 10 2007, 10:32 PM
Senior Member Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains |
I have a pair of 40mm Webers on my 2.0l and back when it was a daily driver I used to throw a drop light under the hood at night so it would start easier in the morning. Wife was always afraid I'd burn down the garage doing this (IMG:style_emoticons/default/tongue.gif)
Now I just don't drive it in the winter (well its a long story, but I sold the car a few years ago and just bought it back in not as good condition so I don't drive it at all right now (IMG:style_emoticons/default/tongue.gif) ). |
GeorgeRud |
Oct 10 2007, 10:38 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I also find that a couple of pumps on the accelerator will richen up the mixture to get it started, then you have to pump it occasionally to keep a six running untill it heats up. Porsche did have a system which pumped raw gas down the venturis from the air cleaner (the holes are still on the six air cleaners),but realized this was a bad idea. The hand throttle was also used to keep the rpms up till it warmed up.
ConeDodger |
Oct 10 2007, 10:47 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
My new 2270 usually starts within 15 seconds with a couple blips of the throtle and then turn the key. She is a little bitchy to start with but settles right down after about 3-5 minutes. I have dual 45 Dells without chokes...
anderssj |
Oct 11 2007, 08:43 AM
Dog is my copilot... Group: Members Posts: 1,663 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
DRLA-40s, no chokes . . . when cold, it's 3-4 pumps on the gas pedal, turn the key and it fires right up. A couple of light "blips" during the first minute or so and it's ready to idle on its own.
Thack |
Oct 11 2007, 08:47 AM
You guys are great! Just the answers I needed to give me confidence to get these carbs on. Thanks again to all of you!
rhodyguy |
Oct 11 2007, 08:54 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/agree.gif) with everyone else. not that big of a hassle. by the time i buckleup and get situated it's good to go. esp with a mallory and 6A box. that was the change that produced the greatest results.
k |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:11 AM |
