OK. So how do I install my new front top/A pillar seal?, after 5 years of reassembly, finally installing side glass... |
jk76.914 |
Oct 13 2007, 06:23 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I just installed my drivers "vent" window, and the aluminum strip to hold the seal along the A-pillar. I have a new seal (hidden away since 1998!), but I can't figure how to install it into the channel. Obviously, the channel gets screwed/adhesived to the A-pillar first, since it has to screw in.
But how the heck to I get the seal in the channel?!?!?! It's too tight to slide down, especially with the curve at the beginning of its trip, and hooking the inside and then snapping the outside in just plain don't work. HELP! Thanks! Jim |
PRS914-6 |
Oct 13 2007, 08:00 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I just replaced every rubber seal in my car. All the seals that fit in a channel were installed by first installing one side and then pushing in the other side. With rubber lubricant or soapy water they go in with no effort at all. All my seals were OEM.
Now if you are talking about the felt seals for the windows, Porsche put out some that will flat not fit in the channel. I spent hours and ruined several during the attempt. I ordered some new ones and they were clearly different (thinner). Actually I think the old stock fits and the newer stock is the ones that are too thick. |
jk76.914 |
Oct 13 2007, 09:33 PM
I just replaced every rubber seal in my car. All the seals that fit in a channel were installed by first installing one side and then pushing in the other side. With rubber lubricant or soapy water they go in with no effort at all. All my seals were OEM. Now if you are talking about the felt seals for the windows, Porsche put out some that will flat not fit in the channel. I spent hours and ruined several during the attempt. I ordered some new ones and they were clearly different (thinner). Actually I think the old stock fits and the newer stock is the ones that are too thick. Thanks for the suggestions. Did you push in with a putty knife or anything? I'll give it a try in the morning. I haven't tried the felt seals yet. Do you mean the ones that go in the horizontal aluminum channel on the outboard side of the moveable glass? I'm not looking forward to those. thanks again, Jim |
Lo-Fi Version | Time is now: 10th June 2024 - 03:20 PM |
