scottb |
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States ![]() |
this occurs even when warm. a winter thing? noticed it in summer but more pronounced now. should i be concerned? anything to loook for initially?
muchas gracias...... |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Cold start injector may be working overtime. Injector seals could be bad.
Do you smell it in the engine compartment, or OutBack? (no rules, just right) M |
scottb |
actually, if at a stand still, smell petrol both in the cockpit and out back.......
hmmmm... me thinks this ain't good. (IMG:style_emoticons/default/headbang.gif) however, i did trace the fuel lines during the summer and they were fine also the fuel pump is doing well in the front trunk position. need to chase this down in the next 4 months once it warms up!!!!! |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Unplug the cold start injector to see if it goes away. Pull a plug or two to see if the are covered with fluffy black soot. Check the MPS with a vacuum pump to see if it holds a vacuum say 15lbs for 5 minutes. Rich running could be caused by these two things.
Injector seals make it run lean. Geoff |
redshift |
Yah, bad injector seals make it run lean because fuel is dumping on the wrong side of the seal.
ARP! M |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Careful what you say there Miles.. you may confuse readers that dont know you.
Bad injector seals allow "extra" unmetered air into the intake valve area causing a lean condition. B |
redshift |
Correct me, go ahead! I am a confusing sob.
Sorry! M |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
Whenever I've been able to smell fuel in the cockpit when standing still it has always been an actual fuel leak. Sometimes it's just something that is "seeping" rather than dripping. I'd look again real hard at all fuel connections for something that is damp and shouldn't be.
Brad Roberts |
Yes Ernie (IMG:style_emoticons/default/pray.gif) this was the intial thought I had..but had too "scold" Miles for his improper scare tactics...LOL
b |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Since the fuel pump is up front, check the fuel lines in the tunnell. If yo have not replaced them, might want to, because they are now under pressure.
redshift |
god this place is screwed up
heh M |
Lo-Fi Version | Time is now: 2nd July 2025 - 12:00 PM |
