Carb fuel pump routing |
KaptKaos |
Oct 14 2007, 01:56 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I am putting in new lines for my carbs. The hard line comes under the car, then connects to the old pumpt and filter. I am using the CB rotary pump and it's almost 12 inches long all in.
There is a mounting point for the fuel filter under the car, but if I try and mount the new filter there, then the lines under the car will be doing loops. Can i mount the pump underneath and then the filter above the tin? Is that a bad idea? Should I be doing this another way (other than moving the pump to the front). Let me know. Thanks! |
rhodyguy |
Oct 14 2007, 02:33 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you can remove the extra canister. it's a carter fuel filter. doing so will shorten the whole aspect of the pump and avoid the loops. hoses are secured with solid clamps which i didn't like the idea of either.
KaptKaos |
Oct 14 2007, 03:19 PM
you can remove the extra canister. it's a carter fuel filter. doing so will shorten the whole aspect of the pump and avoid the loops. hoses are secured with solid clamps which i didn't like the idea of either. Wait!!! You're telling me that the first canister is a fuel filter? It's not a regulator or something? |
Allan |
Oct 14 2007, 04:15 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
The smaller cannister on the input side of the pump is a filter. The pump is internally regulated. You need a filter between the tank and the pump.
If you're going to install the pump in the stock location, put the filter up front under the tank. That's the route I took and it worked out well. |
KaptKaos |
Oct 14 2007, 05:23 PM
Ok, so if I keep the filter that comes with the pump, then I don't need another one in front of that filter then, correct?
Allan |
Oct 14 2007, 05:36 PM
Actually, what I did is buy another FI filter with 3/8th in and out for under the tank because you'll be using the feed line which is larger.
I then used the filter that came with the pump just before the carbs. Carbs like clean fuel and the FI filters do a better job IMHO... |
KaptKaos |
Oct 14 2007, 07:13 PM
How about this:
I leave the filter on the pump and put it in the back of the car. Then, before the T-connector for the carbs, I put another filter? That gets me a filter before the pump and another before the carbs. Does that work well enough? |
rhodyguy |
Oct 14 2007, 07:15 PM
use a stock, big, square filter. if yours is like the cb i got, the short section of hose inbetween the carter filter and the pump has fixed, not removable clamps. you'll have to cut the line just to change the filter and the line will be shorter...everytime.
k |
KaptKaos |
Oct 14 2007, 07:48 PM
use a stock, big, square filter. if yours is like the cb i got, the short section of hose inbetween the carter filter and the pump has fixed, not removable clamps. you'll have to cut the line just to change the filter and the line will be shorter...everytime. k DOH! Too late. I will have to deal with that the next time. Oh well. Anyway, I made 2 jumpers for the power to the pump, one side with a male spade and the other a female spade. How do I know which side connects where on the CB pump? |
KaptKaos |
Oct 14 2007, 08:21 PM
Update:
Got the fuel pump and line run into the engine bay. Mounted the intake manifolds and carbs (thanks Allan!) and I am done for the night. Thanks for the help all. |
rhodyguy |
Oct 14 2007, 08:23 PM
did you use the stock wire harness? if you look at the supplied plug end i think it only goes in one way with a white wire acting as the ground iirc. looking at the haynes (for a 73' usa, as your sig notes) it shows 2 wires for the fuel pump (#9) in the diagram . one labeled black/red and the other brown. the brown harness wire is the ground and connects to the white wire. other to the hot lead. i'm fairly sure. if not the pump will simply run backwards, and you will hear a gurggling sound coming from the gas tank. those would be air bubbles. if so switch the leads at the pump. btdt.
k |
KaptKaos |
Oct 14 2007, 08:30 PM
did you use the stock wire harness? if you look at the supplied plug end i think it only goes in one way with a white wire acting as the ground iirc. looking at the haynes (for a 73' usa, as your sig notes) it shows 2 wires for the fuel pump (#9) in the diagram . one labeled black/red and the other brown. the brown harness wire is the ground and connects to the white wire. other to the hot lead. i'm fairly sure. if not the pump will simply run backwards, and you will hear a gurggling sound coming from the gas tank. those would be air bubbles. if so switch the leads at the pump. btdt. k I looked at the pug under there, and I couldn't tell anything as to + or -. So I picked one. Easy enough to switch when I get to that point. In the home stretch. Very excited. Thanks again! |
Aaron Cox |
Oct 14 2007, 10:17 PM
dont throw away the canister! its a catalytic converter!
LOL - thanks for the laugh on the phone today tho (IMG:style_emoticons/default/tongue.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:59 AM |
