Won't Run, New Info |
JC 914 |
Oct 15 2007, 12:17 PM
Member Group: Members Posts: 124 Joined: 21-June 07 From: Johnson City,TN Member No.: 7,827 |
OK Here goes!!!! The wife and I decide to take a nice mountain drive Sunday after my mechanic (Porsche race car certified) gave me a clean bill of health for my '74 2.0 liter. Drove about forty miles through some of the most beautiful country (near ski slopes), and decided to stop for early dinner. Fabulous outdoor dining, temp about 76, several adult beverages, you know!!!! Got back iin the car to leave dead fuel pump
Left car at the only garage in town, daughter came and got us. Next morning, called Nate in Sacramento(THANKS, NATE!!) He overnighted a fuel pump directly to the garage, DUMBASS installed it, and called to tell me it was ready, but it didn't run just right Long story short, had car towed to my guy (sixty miles), who discovered that DUMBASS had not only kinked the fuel line, but didn't reinstall the fuel filter!!!!!!Who knows what got into my injectors Update soon!!!!!!!!! NOW WHAT??? After three weeks in the shop, running down all the FI components electrically, I'm getting no pulse to the fuel injectors. We even tried replacing the computer with a known working one. HELP!!!!!!!!! |
Cap'n Krusty |
Oct 15 2007, 12:45 PM
Trigger points. Grounds. WTF is "Porsche Race Car Certified"? Never heard of such a title. The Cap'n
Brando |
Oct 15 2007, 02:11 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
WTF is "Porsche Race Car Certified"? Never heard of such a title. Maybe he meant the guy has his DE card for POC/PCA (IMG:style_emoticons/default/lol2.gif) Ideally you want someone who has a fancy aluminum placard (from Porsche) with lots and lots of certification emblems in it. |
jk76.914 |
Oct 15 2007, 09:04 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
There're two relays involved on the relay panel in the engine compartment. #21 is called the "power supply relay". It provides power to the ECU. It also turns on relay #22, which is the fuel pump relay. If #21 croaks, the ECU is out and so is the fuel pump.
My guess is it croaked. If my guess is right, it was your original problem, and your original fuel pump is OK too. Keep us posted..... Jim |
swl |
Oct 16 2007, 05:42 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
does the fuel pump give its little burst on key on? That would prove the ecu is alive.
Electically a break in the wires leading to the MPS will stop all pulses to the injectors. Did it get touched during the trouble shooting? You can learn a lot by making measurements with a multimeter on the ECU cable. I have them written down in my haynes but I think Brad Anders may have them on his site. |
swl |
Oct 16 2007, 05:49 PM
JC 914 |
Oct 19 2007, 12:13 PM
OK, Here's where we are now.
Fuel pump is delivering good pressure Engine starts from cold start valve, but dies when that little bit of fuel is used up Very weak pulse to injectors Trigger points and wiring are good Swapped out ECU for a known working one Wire to MPS is good All grounds are solid All relays are good Multiple grounds at crankcase seam cleaned & replaced ENGINE WON'T RUN!!!!! |
JC 914 |
Oct 19 2007, 02:34 PM
TravisNeff |
Oct 19 2007, 02:58 PM
Check Temp Sensor #2 (cylinder head temp sensor) to see if it is internally shorted out.
JC 914 |
Oct 20 2007, 07:55 AM
toon1 |
Oct 20 2007, 09:57 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Have tou pulled a inj. to see if it's pulsing fuel?
remove the coil wire and one by one remove the inj's. and put them in a jar, crank the engine and see if they pulse fuel. With the motor hot or cold, it doesn't matter. this will tell you if there is fuel. Alway's go to the basics with a prob like this. A motor needs fuel, spark, and compression to run, simple as that. If it's missing one of those elements, NO GO. |
swl |
Oct 20 2007, 09:18 PM
How are you determining that the pulse to the injectors is 'very weak'? Toons right on with the squirt in the jar thing - it will tell you a lot.
I'm really a strong believer in the usefullness of measuring everything possible at the wiring harness of the ECU. That way you can be assured that the all the components are giving (more or less) the correct signal to the ECU. Given that it will start initially you know that your compression, spark and basic fuel delivery is all good. What you have is a failure in the metering system. By the way, it is unlikely that the cold start valve is what is giving you that burst at startup. It does not cut in until very low temperatures. When you key on all four injectors get a pulse. If you listen closely you'll hear them. That is what is giving you the start. The injectors also get an enrichment pulse as you move the throttle. What happens if you feather the throttle when you first start it - will it keep trying to run (poorly). |
toon1 |
Oct 21 2007, 01:00 AM
How are you determining that the pulse to the injectors is 'very weak'? Toons right on with the squirt in the jar thing - it will tell you a lot. I'm really a strong believer in the usefullness of measuring everything possible at the wiring harness of the ECU. That way you can be assured that the all the components are giving (more or less) the correct signal to the ECU. Given that it will start initially you know that your compression, spark and basic fuel delivery is all good. What you have is a failure in the metering system. By the way, it is unlikely that the cold start valve is what is giving you that burst at startup. It does not cut in until very low temperatures. When you key on all four injectors get a pulse. If you listen closely you'll hear them. That is what is giving you the start. The injectors also get an enrichment pulse as you move the throttle. What happens if you feather the throttle when you first start it - will it keep trying to run (poorly). good points, BTW you will see a week signal anyway if you check the elec. pulse at the inj.. It does'nt take much to activate them. It still sounds like there is a fuel clog somewhere |
swl |
Oct 21 2007, 07:53 AM
It still sounds like there is a fuel clog somewhere Given the history of the failure that makes good sense. Perhaps a kinked line on the HP side of the pump that tightens as the fuel pressure builds. Enough pressure for the first bang but pressure drops off immediately. |
rhodyguy |
Oct 21 2007, 09:09 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
have you drained the tank and inspected the fuel sock/strainer on the outlet tube with a flashlight?
JeffBowlsby |
Oct 21 2007, 10:23 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You said you checked the grounds. Did you verify the injector grounds at the rear center of the engine case? Those grounds are critical to the injectors.
JC 914 |
Oct 30 2007, 12:42 PM
OK, new info!!!
Injectors are squirting, and when the fuel pump pressurizes, engine starts and runs very smooth for a couple of seconds. Any attempt to throttle, and it dies out! NOW WHAT? |
tdgray |
Oct 30 2007, 01:40 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Grasshopper... a be so wise as to SHUT UP and go check all the things everyone said. You are going off half cocked and all that will get you is alot of wasted money on parts you did not need.
First off check the T2 sensor. Second check all the grounds...again. Third... how do know that the trigger points are good... did you test them... if you did test them again. Check the fuel like was suggested. Check the fuel lines again... how did you verify fuel pressure. If you do not have a gauge on the rail... get one. THEN... report back. |
toon1 |
Oct 30 2007, 01:45 PM
HHMM, can you tell if the FuelPump stops running after the car starts?
It's not supposed to stop but stranger things have happened. Replace the Fuel pump relay for yits and giggles. Have you tried starting the car with one of the inj's. pulled to see if they stop pulsing fuel? Have you checked the MPS to make sure it holds vac.? when was the last time the fuel system was cleaned, tank and all? Is the fuel filter new? Is there water in the bottom of the fuel tank? It sounds like you are running out of fuel for some reason, still maybe a clog or a kink. The car starting is a good sign. Check everything. Are you doing the work? |
SLITS |
Oct 30 2007, 01:46 PM
Also, check the MPS, both vacuum and electrically.
A rebuilt one in Moab gave up .... luckily I had a spare. First I would check the CHT. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:10 AM |
