Used mallory unilite, what plug wire goes to what plug? |
VaccaRabite |
Oct 16 2007, 06:47 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, as I am setting up my engine for the shakedown fireing this weekend, I put the Mallory on. It has all the plug wire attached to it. How do I figure out what plug wire goes to what spark plug.
Right now the engine is at TDC, and the mallory has been installed as in the manual I downloaded. Zach |
t collins |
Oct 16 2007, 07:54 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
So, as I am setting up my engine for the shakedown fireing this weekend, I put the Mallory on. It has all the plug wire attached to it. How do I figure out what plug wire goes to what spark plug. Right now the engine is at TDC, and the mallory has been installed as in the manual I downloaded. Zach Hey Zach, Remove the dist. cap and note the position of the rotary button it should now be pointing to no. 1, place the no.1 wire in that hole. Now in a clock wise direction on the cap place the no. 4 wire on the cap, then the no. 3 and last no. 2 |
jaybird840 |
Oct 16 2007, 08:34 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Man, do yourself a favor and read the Mallory install threads I posted last week... And for Heaven's sake, make sure it's wired up right. Cost me a $100 bill for having it wired backwards!!!!
--Jaybird |
Aaron Cox |
Oct 17 2007, 11:13 AM
if the engine is at TDC for #1, rotate the dizzy to point at ANY plug on the cap.
You have no arbitrarily selected that node on the cap to be cylinder #1. continue plug wire hook up in the 1 4 3 2 order. (it makes no difference how a mallory is installed, as it is optical pickup vs points) |
Lo-Fi Version | Time is now: 4th June 2024 - 08:11 PM |
