Early vs Late Gas tanks, Is one better than the other? |
PeeGreen 914 |
Oct 17 2007, 12:26 PM
So I know that after '73 the tanks had an overflow/ evap thing on top. Is this better or worse than the older?
And does anyone have the fill neck off an early tank they are not using. I think I would rather have that unless someone can convince me the '74 tanks top are better. |
davep |
Oct 17 2007, 01:09 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I think all but a few very early 1970 cars have the overflow. About the only change I recall is the later plastic fume chamber replaced the steel unit about 1975.
PeeGreen 914 |
Oct 17 2007, 01:23 PM
Must have been late '74 as mine has the plastic. I would like to have to metal one though.
TravisNeff |
Oct 17 2007, 01:24 PM
rhodyguy |
Oct 17 2007, 06:40 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
also the provission for the charcol canister moving to the engine compartment from the tank top must have occured in mid year 74'. recently had 2 74's in the driveway. the 2 routing lines that run up the drivers long, and the 2 small pipes that come thru under the cowl did not exsist in one of them. the canister in the ec tank did not have the mounting bracket on top of the tank.
k |
Brett W |
Oct 18 2007, 09:43 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
I like the screw on top provided by the later tanks. It seems to seal better than the eraly tanks. With a full tank on my 73 I would always have a gas smell and some leakage around the cap. Even with a new cap.
Lo-Fi Version | Time is now: 8th June 2024 - 02:21 AM |
